600E Pro 750MX any build tips, I've opened the box.!
New Toy Tips...
New Toy Tips...
Today's outlook is fine for flying.- Spektrum DX18 gen2, Phoenix Sims, Align MR25XP.
- Flickr Through My Pictures.
Tags: None
Check the instructions and start building it?
http://www.rc-hero.co.uk Models, Spares and Upgrades
"Getting Bigger By Being Better"
you'll have to put a couple of extension leads on. to run the wires round the inside of the frame, with the leads i took off the plastic connector, then used heat shrink once i joined the lead
check this thread
http://www.rcheliaddict.co.uk/t-rex-...ed-please.html
keep us post on how it goes
edited for you KyleOriginally posted by kylelnsn View PostCheck the instructions andstart building it?
Cheers RonOriginally posted by Boggy View Postedited for you Kyle
I guess its finished now Jim? Any photos
Yeah in my dreams still looking at the box picture.Originally posted by kylelnsn View PostCheers Ron
The top mainshaft housing has the lettering facing down, the bottom has it facing up. (Or maybe it's vice versa, I can't remember now but if you don't get it right you will have a lot of vertical play on the main shaft).
Get the motor in and meshed up to the main gear and tightened up before tightening the extra motor shaft bearing bolts.
I had sloppy tail blade grips on mine but I am sure you will have the v2 at least.
Good luck and I am sure you will enjoy it.
I look forward to seeing it.Tron 7.0 advance Vbar evo V Control
build it before you attempt to fly it
the box doesn't fly very wellHirobo Turbulence D3
1/4 scale Vario Bell 47 G3
1/3 scale Vario R22
2012 LHC Scale Cup Judge
If using 3gx then yes, in pc 3gx parameters set 'anti torque compensation to 40% & use outer hole with no sub trim.Originally posted by mr magoo View Posthave guy guy that have one, had the tail bounce when moving to the right with the tail, its ok when going left, also on the servo arm have you used the outer wholes or inner, how much sub trim is two much on setting upToday's outlook is fine for flying.- Spektrum DX18 gen2, Phoenix Sims, Align MR25XP.
Will the 750mx it's crazy I loved mine,just get it built and enjoy itGOBLIN 630 COMP
RAPTOR E700 V2
GAUI X5
GAUI NX5
SPEKTRUM DX9
PHOENIX SIM
I'm a proud member of Http://phoenixrotors.org
You might want to check the mesh of the front torque tube bevel gears. It's often a little loose which leaves the gears prone to stripping. They are prone to stripping at the best of times with the bigger motor but having the mesh tight reduces the problem. You tighten the mesh by using around 0.2-0.3mm of shim washers behind the shoulder of the front TT bevel gear to push it forward a little. KDS do a kit to do this that includes a fancy alloy frame, but you can do it a lot cheaper by just buying the correct size shims: 3RACING
When setting up the governor make sure to have governor gain 'low' (or set manually to a value slightly lower than the '15' low default).. Higher values cause oscillation in the drive train which also tends to strip gears.Goblin Kraken, SoXos Strike 7, XLPower Specter, Goblin Black Thunder T, Goblin 700 Speed, Goblin 770 Comp Carbon, Trex 700X, Kasama Dune, Henseleit TDR
