ELF/DCF Scale Fueslarge
  • ELF/DCF Scale Fueslarge
    Hi Guys
    Would be most Greatful on any feedback
    Question! I know most the Scale Fuselage kits don't fit the Trex 600ELF
    But do any of you guys know of any Scale Fuselage Kits that do fit either the 600ELF or 600DCF trex ! even if i have to do some mods or any suggestions as to the best way to go as regards to a scale fuse for 600ELF or 600DCF trex
    The AS350 is the one i would most like to build.
    cheers AirDog
    The Wife says haven't you got Enough ! the Reply Just Need One More Helicopter !!
    the thunder tiger as355 fits around the trex 600 with very little mods
      You will find quite a few people use 700size fuses with 600 mechanics. take a look at justscale.co.nz, he sells the marvelcraft fuses and ships globally (good prices). For example, many people build the Augusta 109S using 550 or 600 mechanics. It is nto quite plug and play but from comments it is not a massive engineering job either. Ron at justscale is very good at answering questions about his fuses if you contact him. Spend an hour or so on scalerchelis.com and you will find more info from some dedicated scalers.
      Trex 700E DFC HV with BeastX and Gryphon (GVR-7020S)
      August 109S Grand (JustScale.co.nz) 700 size under construction, using trex 700 mechanics.
      Trex 500 EFL stock with new clothes
      Blade 130X with bits on
      Spektrum DX18
        Cheers Bogger & Wheredidthetailgo
        Thanks for the reply
        I was wondering about going up a size regarding the Fuse and putting my trex 600 EFL in 700 Fuse I don't mind doing some mods as this is all part of the fun.
        I do like the AS355 must admit...
