Hi Guys, I need to know what pack sizes to use on a trex 600 i am thinking about building. I have some opti 6s 5000mah packs I would like to use. Would this be possible at all?
Thanks in advance.
Jr forza 700 - one mean machine!lol Logo 600sx v2- the big boy Trex 550l- crazyness Optim 80cp- Just amazing!
Ideally a pair of 3300 to 3500 6s packs are the common choice, you will be hard pushed to load 5000 packs in an May be a bit weighty but worth a try, be a good flight time.
You will need a different KV motor (high 500's) and a different pinion but its quite possible you could, if your 10s are 4000ish. Need to watch that your ESC is up the job though, as at a lower cell count you will be pulling more current
Logo 600 3D --- Vortex Vx1n
JR Forza 700 --- Vortex Vx1e
you would need to work out your kv from the headspeed you want to run and pinion availability.
I would think you would need a 560kv and a 120HV ESC. the 80HV the 600 comes with as a super combo is fine on 12S but I wouldnt want to draw the extra amps on a 10S setup.
The biggest question is will they physically fit, and I guess you need to find someone local to you to see if they will actually load up properly.
The super biggest question to me is why you would be flying a 600DFC if you have a logo 600sx?
I had a 600e pro and a 600sx and I had more fun with the 600 e pro, probably something to do with the crashability lol
i had a 750 mx in mine, it was wikid it had silly power
