What a great Idea!!
Looks cool. Would be good to see how this would work in flight. Obviously when u land and measure there is no load in the packs. But in flight the reading would be different?James
SEMAS Flying Club
Exactly, so bringing the heli into a hover and reading the display will have a nominal load on the pack, so will give you much useful info than a 'no-load' test. I'm not a lecky flyer at all, but the obvious question for me is how would you relate a 0-9 scale into actual LiPo charge, and what does zero mean? Does it mean 'zero' charge or does it mean 25% left or something?Originally posted by KnifeEdge View PostLooks cool. Would be good to see how this would work in flight. Obviously when u land and measure there is no load in the packs. But in flight the reading would be different?
Sorry, haven't read the specs if it's already posted there, just looked at the pictures.JR Vibe Fifty fb (YS56)
me to would want to no this info but looks good to me.Originally posted by Steve View PostExactly, so bringing the heli into a hover and reading the display will have a nominal load on the pack, so will give you much useful info than a 'no-load' test. I'm not a lecky flyer at all, but the obvious question for me is how would you relate a 0-9 scale into actual LiPo charge, and what does zero mean? Does it mean 'zero' charge or does it mean 25% left or something?
Sorry, haven't read the specs if it's already posted there, just looked at the pictures.RAPTOR 60
TREX 500 CF, FBL
MSR-X
JR XG7
__________________________________________________ ______________________
http://www.hdrcmc.co.uk/index.htm
Ive setup some think very similar on my 450 a year or so ago, took it it off after a few flights as in some lights its very difficult to see and once you have it in mind to look you waste lots of time until you do ... imho a total waste of time sorry !!
700 Nitro Beastx V3 RL100H installed awaiting pipe
600 PRO EFL Beastx V3
Velocity 50N Beastx V3
Trex 600E test machine
Gaui 200
Hi all,
I have just had one of these ACE RC TT8086 power monitors to my Trex 550, my opinion is that it looks good and fitted well on the side of the chassis, however there is a big problem with the monitor and that is accuracy.
Basically, the TT8086 under reads by up to 20%, so on a fully charged battery which is showing almost 4.2 volts per cell when checking via the battery balancing leads using a run of the mill battery checker, however the TT8086 will show a "7" on the display which indicates that there is only 4.0 volts per cell. Then after a short bit of flying, it soon drops to "6" and before you know it it is flashing "3" indicating you should land as the voltage is now 3.6 volts per cell. Upon landing and checking the battery via the balancing lead you discover the battery actually has 3.9 volts per cell and the monitor should still have been showing "6".
I asked the chap at the local Sussex model centre who fitted it for me if he knew why it may be doing this but he was unable to help and so i contacted Thunder Tiger Corp who make it, their response was less than helpful as they said they too had noticed that it under reads as well and that they had never seen more than an "8" on a fully charged battery (8 means 4.1 volts per cell). I think the monitor is totally useless as a real time diagnostic tool unless anyone out there had a bright idea on whether the connections can be modified to change the configuration?
The connections as as follows:
1 lead soldered to battery ESC terminals
1 lead to BEC output from ESC and receiver (Y lead)
1 lead to receiver
1 jumper plug to set battery type
1 jumper plug to identify how many battery cells
Im thinking of removing it and just buying a DX8 with telemetry instead which is aparantly very accurate.
Any help or comments would be gratefully received.
Thanks,
Mike
Thanks for your replies, perhaps it is the case then that all battery monitors that measure the power at the receiver are going to be incomparable to the balancing leads, but which way is more correct. The manufacturers must have thought of that through when they designed them i would have hoped. Perhaps we should not be bothering to monitor in the 1st place and we should just rely on the esc to tell us when its time.
If you want to know what's going on with your electrics while flying fit one of these VoltMagic R/C Voltage Monitor with Glitch & Failsafe counting
great bit of kitThe Fleet
Trex 450 Pro on Brain 2
Mini Titan super Cobra ah1
Alien 550 Quad.3DR Pixhawk
Futaba 7C 8FGS 14SG
Specktrum DX6i
Still for me the best way is to fly on a timer, and see how many Mah you put back into the pack. Then adjust your timer to suit.
I have flown a foamy plank with a low voltage buzzer, and any time you hit full throttle it would buzz even on a full pack.Henseleit TDR
V-Bar x2
SAB Goblin 700 V-Bar
T-Rex 700e DFC V-Bar
Synergy N7 V-Bar OS105 HZ-R
Synergy E7se V-Bar
Synergy N5c FBL V-Bar
Gaui NX7 V-Bar YS91 Tareq SRX
T-Rex 550 E FBL V-Bar
Gaui NX4 V-Bar
x 3
