Bought some adapters and need your opinion.
  • Bought some adapters and need your opinion.
    Hey guys!
    I bought some. 5mm bullet to ec5 adaptors to.use on my 700e but I am not sure they are going to be man enough to handle the current!
    [url=http://www.hobbyking.com/hobbyking/store/__24420__EC5_to_5_5mm_Bullet_Connector_Battery_Adapter_2pcs_bag_.html]EC5 to 5.5mm Bullet Connector Battery Adapter (2pcs/bag)[/url]
    I was intending to use them on a stock Trex 700e with castle 120a etc and a pair of 30c 5000mah 6S lipos.
    What do you recon?
    Gary
    Futaba 14sg
    Hey Gary.
    More than man enough mate, I use EC5's on my 700E DFC as do many others and they work well. I think EC5's are rated to 120amps+ continuous.
    Ian Contessa
    Coolice Power Supplies
      My guess is they will be fine, more than enough to handle the power.
        [QUOTE=gazmk2;1105715]Hey guys!
        [URL="http://www.hobbyking.com/hobbyking/store/__24420__EC5_to_5_5mm_Bullet_Connector_Battery_Adapter_2pcs_bag_.html"]EC5 to 5.5mm Bullet Connector Battery Adapter (2pcs/bag)[/URL]
        What do you recon?
        Gary[/QUOTE]
        Hi Gary
        I brought them with the same intention as you , and didn`t think they were up to the job so soldered Ec5`s on instead.
        Having said that the wire on them is like a copper and you try de-soldering one ,it melted bullet before the solder.
        The sodering job is not very good on mine ,only a dab of solder on each wire.
        Not worth the cost of a crash if they fail.
        Just my opinion
        regards
        Ian
          Thanks for the reply guys, that makes me feel a little more confident in my maiden flight!
          Why on earth did I put this in "women pilots"?? I mean, it's not even the weekend yet!!
          Futaba 14sg
            [QUOTE=gazmk2;1105727]Thanks for the reply guys, that makes me feel a little more confident in my maiden flight!
            Why on earth did I put this in "women pilots"?? I mean, it's not even the weekend yet!![/QUOTE]
            Yeah just to add, those wires may not be as thick as the wires on the Turnigy 5000mah packs but they put really overkill guage wire on there, in a 12s setup you'll never pull enough power to stress those wires! Just make sure they are securely soldered as they should be.
