[FONT=Calibri][SIZE=3][COLOR=#000000]Hi All,
I hope this is the right section to do my review on this quadcopter (I know this is a Heli forum but this is RTF FPV so should still be of interest).
Mods please move this if I have placed it in the wrong place.
[/COLOR][/SIZE][/FONT]
[FONT=Calibri][SIZE=3][COLOR=#000000]I recently purchased a RTF FPV Quadcopter from BestGear.com.I was looking for a cheap and cheerful RTF quad that I could give to my nephewas a present to see if he could learn to fly FPV without destroying any of my frames in the process.
[FONT=Calibri][SIZE=3][COLOR=#000000]I decided on the [/COLOR][COLOR=#333333][FONT=Times New Roman]SKY HawkeyeHM1315 Quadcopter 5.8G FPV
[/FONT][/COLOR][/SIZE][/FONT]
[SIZE=3][FONT=arial][URL="http://www.gearbest.com/rc-quadcopters/pp_126130.html"][FONT=Times New Roman][COLOR=#0000ff]http://www.gearbest.com/rc-quadcopters/pp_126130.html[/COLOR][/FONT][/URL]
[/FONT][/SIZE]
[COLOR=#333333][FONT=Times New Roman][FONT=Calibri][SIZE=3]I was very impressed with the delivery time,I received this package 3 working days later...[/SIZE][/FONT][/FONT][/COLOR]
[IMG]http://i.imgur.com/hfDizdwl.jpg[/IMG]
[IMG]http://i.imgur.com/esc1A7Vl.jpg[/IMG]
I was also very impressed with the packing...
[IMG]http://i.imgur.com/204Iavxl.jpg[/IMG][/SIZE][/FONT][/FONT][/COLOR]
[COLOR=#333333][FONT=Times New Roman][FONT=Calibri][SIZE=3]Here is the box with all the details...[/SIZE][/FONT][/FONT][/COLOR]
[COLOR=#333333][FONT=Times New Roman][FONT=Calibri][SIZE=3]Back:[/SIZE][/FONT][/FONT][/COLOR]
[ATTACH=CONFIG]80332[/ATTACH]
[COLOR=#333333][FONT=Times New Roman][FONT=Calibri][SIZE=3]Front:[/SIZE][/FONT][/FONT][/COLOR]
[IMG]http://i.imgur.com/o4aAso8l.jpg[/IMG]
[COLOR=#333333][FONT=Times New Roman][FONT=Calibri][SIZE=3]Left:[/SIZE][/FONT][/FONT][/COLOR]
[IMG]http://i.imgur.com/YvLzWwDl.jpg[/IMG]
[COLOR=#333333][FONT=Times New Roman][FONT=Calibri][SIZE=3]Right:[/SIZE][/FONT][/FONT][/COLOR]
[IMG]http://i.imgur.com/Kcuabhsl.jpg[/IMG]
Inside the box all the items are kept separate in some molded plastic, no damage was found on any of the items...[/SIZE][/FONT][/FONT][/COLOR]
[IMG]http://i.imgur.com/TALWP27l.jpg[/IMG]
[COLOR=#333333][FONT=Times New Roman][FONT=Calibri][SIZE=3]Here is the Quad and the separate camera/FPV transmitter...[/SIZE][/FONT][/FONT][/COLOR]
[IMG]http://i.imgur.com/urxSp0bl.jpg[/IMG]
[COLOR=#333333][FONT=Times New Roman][FONT=Calibri][SIZE=3]Here is the remote Tx and also the FPVscreen/ DVR unit which comes fitted with a 4Gb micro SD card...[/SIZE][/FONT][/FONT][/COLOR]
[IMG]http://i.imgur.com/wOVlZT8l.jpg[/IMG]
[COLOR=#333333][FONT=Times New Roman][FONT=Calibri][SIZE=3]On the underside of the box is a small bag containing all the extra’s needed for the quad...[/SIZE][/FONT][/FONT][/COLOR]
[IMG]http://i.imgur.com/uRApNWJl.jpg[/IMG]
[COLOR=#333333][FONT=Times New Roman][FONT=Calibri][SIZE=3]This includes...[/SIZE][/FONT][/FONT][/COLOR]
[COLOR=#333333][FONT=Times New Roman][FONT=Calibri][SIZE=3]4 prop guards [IMG]http://i.imgur.com/nrPVqyXs.jpg[/IMG][/SIZE][/FONT][/FONT][/COLOR][ATTACH=CONFIG]80333[/ATTACH]
[COLOR=#333333][FONT=Times New Roman][FONT=Calibri][SIZE=3]Screw driver with 4 (+2spare) screws used to attach the prop guards[/SIZE][/FONT][/FONT][/COLOR]
[COLOR=#333333][FONT=Times New Roman][FONT=Calibri][SIZE=3]Full set of spare props (2cw, 2ccw)[/SIZE][/FONT][/FONT][/COLOR]
[COLOR=#333333][FONT=Times New Roman][FONT=Calibri][SIZE=3]USB charger for the flight battery[/SIZE][/FONT][/FONT][/COLOR]
[COLOR=#333333][FONT=Times New Roman][FONT=Calibri][SIZE=3]USB charger for the FPV Screen/DVR[/SIZE][/FONT][/FONT][/COLOR]
[COLOR=#333333][FONT=Times New Roman][FONT=Calibri][SIZE=3]700mAh 1s Lipo [ATTACH=CONFIG]80334[/ATTACH][/SIZE][/FONT][/FONT][/COLOR]
[COLOR=#333333][FONT=Times New Roman][FONT=Calibri][SIZE=3]2 sticks for the RC Tx[/SIZE][/FONT][/FONT][/COLOR]
[IMG]http://i.imgur.com/xFXqN2Nl.jpg[/IMG]
[COLOR=#333333][FONT=Times New Roman][FONT=Calibri][SIZE=3]Here is the separate camera and FPV transmitter which is powered straight from the quad itself, it has a slot forthe micro-SD card that records the flight video or photo’s...[/SIZE][/FONT][/FONT][/COLOR]
[IMG]http://i.imgur.com/gvy2IgMl.jpg[/IMG]
[IMG]http://i.imgur.com/AWh9mf6l.jpg[/IMG]
[IMG]http://i.imgur.com/AeYTKzIl.jpg[/IMG]
[COLOR=#333333][FONT=Times New Roman][FONT=Calibri][SIZE=3]As you can see you can angle the camera to point the desired direction separate from its main body which is clipped to the underside of the quad.
[COLOR=#333333][FONT=Times New Roman][FONT=Calibri][SIZE=3]The FPV screen/DVR is an amazing bit of kitfor the price...[/SIZE][/FONT][/FONT][/COLOR]
[IMG]http://i.imgur.com/G0i5Kqdl.jpg[/IMG]
[COLOR=#333333][FONT=Times New Roman][FONT=Calibri][SIZE=3]The photo does not show very well but there are 5 buttons on the front under the screen (View, Rec, Photo, Up, Down). You can choice to record video or take photo’s while you fly via this screen, Iguess it must have a bi-direction comms to achieve this as the files are saved to the SD card on the quadcopter and not the one in the DVR unit. After you have captured some video or photo’s you can transfer the SD card into the DVR unit and play back what you have captured in brilliant colours and sharpness...[/SIZE][/FONT][/FONT][/COLOR]
[IMG]http://i.imgur.com/sdNZxLjl.jpg[/IMG]
[COLOR=#333333][FONT=Times New Roman][FONT=Calibri][SIZE=3]I assume from a single charge that 10-15minutes worth of viewing will be capable by this screen.[/SIZE][/FONT][/FONT][/COLOR]
[COLOR=#333333][FONT=Times New Roman][FONT=Calibri][SIZE=3]The underside of the quad is fitted with 4 strings of 3 LED lights housed in the four arms, Green in the front and red in the back arms, this should help a lot with orientation...[/SIZE][/FONT][/FONT][/COLOR]
[IMG]http://i.imgur.com/LXu98WPl.jpg[/IMG]
[COLOR=#333333][FONT=Times New Roman][FONT=Calibri][SIZE=3]Here you can see the red On/Off switch(bottom), the FPV camera power socket (top), the clips for holding the FPV camera on (middle&right), FPV camera power socket (top) and the flight battery hatch (back)[/SIZE][/FONT][/FONT][/COLOR]
[IMG]http://i.imgur.com/1Y4o66sl.jpg[/IMG]
[COLOR=#333333][FONT=Times New Roman][FONT=Calibri][SIZE=3]The 700mAh 1s Lipo sits in a nice black cage inside the main body of the quad, you can connect the power and close the hatch as there is a On/off switch on the outside of the quad for easy access...[/SIZE][/FONT][/FONT][/COLOR]
[IMG]http://i.imgur.com/C6bnmr1l.jpg[/IMG]
[COLOR=#333333][FONT=Times New Roman][FONT=Calibri][SIZE=3]Zooming in on this image I can see that the main board looks like it is mainly automated soldering that has taken part but there are some signs that there has been some manual soldering, the quality of the work looks very good indeed.[/SIZE][/FONT][/FONT][/COLOR]
[COLOR=#333333][FONT=Times New Roman][FONT=Calibri][SIZE=3]Inside the arms looks to be about 8mm coreless motors using a gear system to decrease the speed and increase the torque needed to rotate the large props. The gears seem of good quality, the main gear looks to be nylon which should stand up to quite a few hard knocks without burring any teeth, the main shaft seems to use sealed ball bearing to keep the movement smooth ...[/SIZE][/FONT][/FONT][/COLOR]
[IMG]http://i.imgur.com/ozZO4qkl.jpg[/IMG]
[COLOR=#333333][FONT=Times New Roman][FONT=Calibri][SIZE=3]Here is an arm with the prop guard fitted using the screwdriver and screws included in the box...[/SIZE][/FONT][/FONT][/COLOR]
[IMG]http://i.imgur.com/fywwAovl.jpg[/IMG]
[COLOR=#333333][FONT=Times New Roman][FONT=Calibri][SIZE=3]Here is the camera attached to the underside of the quad, it toke quite a firm push to get this to attach and once there it has very little to no flex of movement, the camera can then be tilted to your desired angle for flying...[/SIZE][/FONT][/FONT][/COLOR]
[IMG]http://i.imgur.com/ak2sOH3l.jpg[/IMG]
[COLOR=#333333][FONT=Times New Roman][FONT=Calibri][SIZE=3]The mono-pole vTx antenna does sit over the battery hatch which makes it hard to connect and disconnect the lipo without bending it out the way but this is not an issue as the antenna is made from good quality cable.
[COLOR=#333333][FONT=Times New Roman][FONT=Calibri][SIZE=3]Here is the quad all setup and ready for its first test fly...[/SIZE][/FONT][/FONT][/COLOR]
[IMG]http://i.imgur.com/L2HSbYcl.jpg[/IMG]
[IMG]http://i.imgur.com/syPRrYZl.jpg[/IMG]
[IMG]http://i.imgur.com/Vms406Jl.jpg[/IMG]
Without prop guards fitted:
[IMG]http://i.imgur.com/vkDZB66l.jpg[/IMG]
I will make a video showing the quad in action as well as showing the FPV footage I record on its DVR when the weather gets a bit better.... Of course I have to test these things before I let the little lad have a play... that’s the rules lol
Just spotted they have some offer on at the moment to grab some cheap RTF Quadcopters...
[URL="http://www.gearbest.com/m-promotion-active-126.html"][COLOR=#1155cc]http://www.gearbest.com/m-[/COLOR]promotion-active-126.html[/URL]
or I found a coupon code for the above Quad: HM1315[/SIZE][/FONT][/FONT][/COLOR]
[/FONT][/SIZE]
