Evening folks,
Took my rappy 50 out to the field today to flight trim and tune high speed needle. Had the engine sounding nice at around hover with back plate cool to touch and pinch test working (at idle).
However when dropping the stick from hover to idle the engine would stutter before settling to an idle. By stutter I mean it sounded like it was revving constantly before dropping to idle.
I thought the low end might be a bit lean (my thinking was that the engine was strugging to get fuel) but when slightly richening the low needle the idle would not keep itself consistent, and would eventually kill the engine. Before the adjustment the low needle was pretty much factory setting (flush with carb body)
Anyone else came across this?
