hi im billy nice to meet all you lovely heli addicts , I have just purchased a raptor 50 with a futaba ff9 tx and a gy401 giro, can any one give the setting to setup my tx to learn on to make it rather docile many thanks billy.
beginner help
beginner help
Hi billy
You need to set the dual rate and expo setting to some thing like
Dual rate = 85
Expo =30
This will dumb down to a reasonable noob setting , it's rate individual what you set the DR & Expo setting , try the above if you want it more responsive just lower the values till you comfortable with how the heli responds.
Nano CPX, 2 x blade 300x, blade 450 (sk720 FBL), align250
Re: beginner help
I'm only a relative beginner myself, is an 85 rate a bit high for a beginner and would reducing the 85 rate make it more docile rather than less ? Or am I missing something.Originally posted by kieranar View PostHi billy
Dual rate = 85
Expo =30
Setting up a dual rate at less than 100% is essentially the same in effect as reducing the servo throws, so no matter how far you move the stick the overall swash movement is less (or put another way, you must move the stick further for the same amount of swash movement).Originally posted by Ritchieme View PostI'm only a relative beginner myself, is an 85 rate a bit high for a beginner and would reducing the 85 rate make it more docile rather than less ? Or am I missing something.
Expo affects the area at the stick centre and doesn't limit the overal throws / max movement of the swash.
I learned on a Raptor 30 V2 and have never used dual rates myself but it's easy enough to set and then you can try both switch positions and see how it feels. I also started out with very little expo but now I generally have about 15 to 18% expo on elevator, aileron and rudder.
With the Raptor, if you have the black paddles fitted and assuming the rotorhead has not been modded it will be pretty docile without having to do anything else really.Kasama, Minicopter, Henseleit, JR, Shape, Beam
Proud recipient of 7 EGS!
and a platinum star
Agree with advice so far reduce the rates slightly and add some expo (15-20% would be my choice but this is personal preference).
Most importantly though make sure you have a sensible head speed around 1700 is ok, this is done by balancing the throttle and pitch curves (unless you have a governor of course) higher head speeds make the Heli more lively and a bit more intimidating.
If you are very new to this try and find a club to help you get the basic settings correct.Align 700N
Align 600N
Align 550L
Goblin 380
Lynx Oxy2
2 Dumb Thumbs!
