I've still got the mCX2, great indoors and for learning, but the Blade 450 3D is starting to get more airtime now. It's been out several times; twice on and over the lawn, then yesterday on the village playing field, larger, short grass and no leaves! I got through half a battery then a gust caught me and I had a hard landing from about a metre up. Not too bad, it just tipped over in spite of training legs and damaged the end centimetre of plastic, fortunately no damage to the wood blade - I was quite proud in a way, I've practiced the power-cutting reflex as recommended, and I'd chopped the throttle when I realised things were unrecoverable (for me!), so the blades weren't at full speed when they hit. I thought about keeping things unchanged, the cracked plastic made a sound like a small Tornado, very macho! It then started to rain, so I took the hint and gave up for the day.
In the garage, blade tips were reinforced with tape, taking care to use exactly the same amount in the same position on both blades, to keep balance. Heart in mouth, fired up this morning on the lawn, no vibrations!! Also no fast-jet roar
More seriously, I've got it hovering and small trips around the lawn, mostly under control, and no more crashes. It seems very quick responding to commands compared to the mCX2, but after the small co-ax at least I know what I SHOULD be doing, and by the second flight this afternoon it was hovering quite well in spite of a slightly gusty wind.
I was trying to follow the training videos from rchelicopterfun.com, which suggested keeping low, sort of rolling over the ground on the training feet at first. He was on tarmac; I am on grass, and there was a tendency to tip forward on the front rollers; also when in a low (20-30cm) hover the right side dropped and I ended up having to put some left cyclic in to stop it drifting right with the rotor close to the ground/flowerbeds. This right-hand-down attitude was much less apparent with a bit more altitude and so less ground effect, so I think the rchelicopterfun.com video should make it clearer that grass has considerably more friction (to be fair it is discussed, his recommended surfaces are hard like tarmac or hard snow).
My confidence is back up after yesterday's incident, tomorrow's forecast is for less wind so it's back to the playing field. When I'm more confident near the ground (take-off and landing), there's a set-aside field over our fence for me to use, but the grass is currently about 10-20cm and a lot of loose cut grass, I can see some tippy-over landings!
Anyway, I'm really enjoying the challenge so far, great hobby!
Owen
Owen
You should be able to pick up a 2nd hand mcpx quite cheap now that the nano is out!
