more hummingbird noob questions
  • more hummingbird noob questions
    More help needed please?
    I have now got the thing (Hummingbird V2 with Airwolf Body) and done a basic test,all functions working correctly on the ground (air test tomorrow hopefully), but a few important questions (well for me anyway).
    Can I fot the trainging pack with the Airwolf kit, it doesn't seem so, I see how it would fit to a standard hummingbird, but not the Airwolf kit.
    I really could do with getting this sorted as I know Iwill have crashes and wreck it without the training pack.
    When I power up the main rotors the HB tail rotates counter clockwise, I can check this with the tail rotor stick,but can I do anything to stop this automaically, the gain swithches on the mixer and gyro board maybe???
    Last but not least (and sorry for being a TOTAL amateur) bit is the gyro on the V2 hummingbird installed on the mixer and gyro board, the reason Iask is that I do not have a seperate gyro to install (my pack has two servos, a receiver board and a mixer/gyro board.
    All help as always - really appreaciated.
    If possible, I would stick with the std setup i.e. no airwolf fuse and put on the training gear.
    The hummingbird is not my strength, but many of these heli's have the gyro, rx and speed controller as one unit and I doub't you'll be able to stop the tail from stopping. The tail will be driven I suspect from the gyro / tail input's. Therefore as the heli spool's up the greater the torque generated and the tail will aim to compensate for this.
    Apologies for being a bit late, I hope your flight test went okay.
    Stuart
      Thanks for the reply Stuart,
      I have found a way of rigging the trainging gear - it is however a little higher than Iwould like - but it will at least give me a little more help and protection from crashes.
      Cheers - Jason
      ps - Test flight delayed and now tomorrow (Thursday) will post results- good or bad!
