Noob with new Hummingbird - help greatly appreciated
  • Noob with new Hummingbird - help greatly appreciated
    Hi there,
    brand new to this,got a hummingbird with Awolf body for xmas-setting up at the mo and stuck with the servo install (I know very poor),
    what I need to know is do Isimply stick them on with the pads supplied and which servo horn do i use? And do Icut the cross head horn to make a single arm one?
    Any help with my set up reallyappreacited, I can't wait to get going with this.
    JB
    JB
    The servos are fixed on with the tape. Cut the horns to suit. EG, if you have one push rod, then only one horn is used. The rods normally go into a hole about 10mm from the centre. Try and get the horns as near to 90 deg as possible when the transmitter sticks are centred.
    If you are using the 4 ch transmitter, as far as I can remember, all channels except 4 are reversed.
    Ant
      Thanks for the help Ant,
      also found an excellent updated instruction set for the V3Hummingbird on theCentury site, much better instructions.
      JAse
