Trex 250 with devo 7 help please..
  • Trex 250 with devo 7 help please..
    First off all would the devo 7 work with the trex 250? I also have the ASSAN GA250 I need help in figuring out where all the servo's and gyro hook up to. Please help
    Your best bet is download the manuals.
    • Flickr Through My Pictures.
      I do have the manual..It does not have enough directions.
        Hi, you might try to get some gyro info from the 'Setup Thread', there is a thread in there concerning the Assan gyro so i guess someone there will have more info for you, i believe you will find some youtube vids that will guide you with the setup too.
        It would be difficult for people to advise you with wiring not knowing what TX, RX & servos you will use.
        The Devo 7 is i think a walkera TX so not so sure you can set it up on a 250 unless your using all the electrics that go with the TX ie; servos and RX.
        hope this helps a little.......
        Brain Goblin 380. Brain Goblin 500 sport. Spirit Trex550e DFC. (BeastX Trex450Pro, BeastX Trex550e DFC... in Thailand)
        Brain Oxy 2, Nano CP X BL.
        neXt-Heli, DX9. DX6 G2. PL8 + Coolice 2400W PSU.
          Thanks for the reply. I got the servo's pluged in the RX(rx4701) and only two out of the three moves but not all at the same time. i will slao visit the gyro section on the ASSAN. thanks bro
            Has tx got ccpm where you can set 120 = 3 cylic servo's .?
