Looking at getting another Heli..
  • Looking at getting another Heli..
    But I was wondering which out of the MCPX or the Blade SR is better or better suited for a beginner? I want to progress into flying 3D and from what i have seen both these Helis are capable of 3D flying. But which is the better option?
    Where will you be flying?
    Rich
    SAB Goblin 700C - Black Nitro
    Flight Log
    THE MEDWAY MASSIVE
    WEBSITE FACEBOOK
      Both indoors and out side, have a small field near by
        If you have some basic heli skills I'd go for the MCPX with dual rates on.
        Yan
        XL Protos 380, XL Power Specter 700, Align 700Top Dom, Green & Black Vbar Controls.
          Ok, I must admit the MCPX is taking my fancy
            I would go the MCPx route but flying indoors is a bit more risky as furniture is hard and grass is soft lol. Like yuppyflier said put dual rates on as this heli is very twitchy to start with.
            Rich
            Flight Log
            THE MEDWAY MASSIVE
            WEBSITE FACEBOOK
              bet there will be lots of cheap MCPX's for sale shortly when the 130x lands.
              Yan
                It depends on the beginner. Some of us like a challenge and others like an easy life. Smaller helis like the mcpx flown outside over grass are very survivable. They are not easy. Try the mcpx and find out its pros and cons and then go from there. If you find it too difficult or you want to do more outdoors or indoors you can leave it for a bit, get another more suitable heli and come back to it. I assume you have Phoenix...
                Blade 130-X, MSR, MSRX
                Phoenix Sim
                  I've flown the mcpx and mini cp, the mini cp kicks the mcpx's arse... the only problem with the mini cp is people's hatred for all things walkera.
                    I have an mCPX and used to have a Blade SR - I would recommend the mCPX.
                      Personnally I wouldnt bother with the Blade SR, it can fly 3D, but the tail doesn't hold very well (motor driven), the parts are mostly plastic and there is there is lots of slop in the rotorhead. I would not say it is value for money atall. Maybe an Esky Belt CP? I have an Esky Belt CP V2, and they have launched a new one as well. Take a look at the belt cp X. Its cheaper and better than Blade SR. If you do do that though I reccomend that you buy some heavier blades, as its quite twitchy with stock ones. 002793 Belt CP X - Belt CP-for the heli. And HS1162 325 Carbon rotor blade weighted - Trex 450 for the blades. Good luck with whatever you decide!
                        Make sure you get a training kit aswell, very difficult learning to hover without one
