help with blade huey
  • help with blade huey
    hi im new to the forum and new to helis the problem ive got is my blade sr uh-1 huey just keeps spinning round soon as i power up i think im having trouble setting it up is there any sort of a starter setup that i could try the other problem ive got is understanding the instruction manual and the transmitter has an f mode a d rate an sm tcm adj +&- dial anouther dial with ch5 +&- what do these do if i can understand some of it i may be able toi make a start on flying
    thanks in advance
    gaz
    thanks in advance
    gaz
    you need to be carefull and understand the manual . it may be spinning because the gyro is in reverse should say norm /rev on gyro . different modes are for different flying ie stunt where the pitch changes from posative to negative at centre stick . if you have it in stunt mode by accident you will either destroy it or injure yourself badly . you need to read the manual though .. regards..and be carefull..
      ok let start from begining
      do you know where the gyro is ?
      should look like this
      Century Robinson R22 (waiting engine replacement)(job 2)
      Align T-rex 500 (in service)
      Align T-rex 450 pro v1 (in service)
      Hirobo Lama (awaiting overhaul)(job 3)
      Align T-rex 600n pro (in service)
      Align T-rex 700n pro (being over hauled)(job 1)
