Preventing a boom strike...
  • Preventing a boom strike...
    I read somewhere that if you increase the pitch to +2 degrees at 0 throttle and tightened the blades in the blade holders that it would help prevent boom strikes. Is there in truth in this?
    • DX7
    • TREX 450SE V2
    • TREX 600N Pro
    Depends how hard you hit the ground.
    You must not tighten the blades too much or they cannot settle into their natural 'lead' and 'lag' when rotating and cause vibration.
    Usually a boom strike can occur when the throttle has been 'chopped' down to zero which would give you 0 degrees or negative pitch if learning, hence the boom strike.
    sigpicx2
    Airskipper 50 - For sale
      Might sound daft but you'll have a hell of a time getting the thing down if there's much more than a gentle breeze without a small amount of negative pitch. When you get gusts lifting it up negative comes in handy
      Velocity 50
      Synergy N5
      Fury 55 FBL
      Trex 700
        Hi Nerra.
        Yes your right. but you need to set the pitch range to -2 to +10 on normal throttle.
        I also set my throttle to stay at -2 untill just below 50% throttle.
        As a result after the first three boom strikes on any kind of slightly heavy landing I have not had one since.
        I can now hover the heli and if it lands a bit rough I have not had any problems since.
        Theres some good info about the Belt CP and setting it up here http://www.heliguy.com/Forum
        Hope that helps.
        Regards
        James
        ONE Eddie Gold Star!
        Kinross Radio Model Flying Club
          Very true... in this scenario, descending involves losing so much head speed to stop the blades lifting, it puts you (or the heli!) in a bad situation.
          -1deg minimum is a fair call. Boom strikes only happen when you bang it hard.
          Cheers - Rob
          T-Rex 600CF-E * GY601 Gyro * S9251 digital Tail * S3152 digital Cyclic * 2x 4800 Aurorra LiPos * 600L Motor * TT composite 600mm blades
          3DX-400 Hybrid parts bin special * GY401 Gyro * Robbe 0.054sec digital tail * All CF/Aluminium construction bar plastic main gear
          Wren MW54 Gas turbine Jet-1 trainer * FF9 Super Radio * Phoenix Sim * Understanding wife * Unhappy bank manager
            Originally posted by Dashik View Post
            Hi Nerra.
            Thanks Dashik. I'm not quite sure what you're saying there... Do you mean you've set it so that the pitch is at -2 until you reach 50% throttle? I presume you've had to program your TX to do this. Did you have the 3 boom strikes before or after you had this setting? At the moment I'm using the stock ESKY TX but I should be a getting the DX7 this week.
            By the way, are you using the standard esky ESC with your DX7? Someone said on the heliguy forum that he could not get it to initialise with the DX7.
            • DX7
            • TREX 450SE V2
            • TREX 600N Pro
              Hi Nerra,
              That's right -2 untill 50% throttle then 0 pitch at 50% then +10 at 100% throttle.
              I'm actually thinking of increasing the head speed at 50% throttle to help avoid the rise and fall you get from the heli in hover's. (Probably to 60% throttle at 50% stick travel.
              Boom strikes were prior to this setup.
              I'm using an ar7000 with the specktrum DX7. You wont get the esky Rx to initialise with the DX7 as its not 2.4 Ghz.
                Thanks again. I will try and set mine up to do the same.
                I know the ESKY Rx won't work which is why I'm getting the AR6100 but I wanted to know if you were still using the standard esky ESC (speed controller) ?
                • DX7
                • TREX 450SE V2
                • TREX 600N Pro
                  LOL, that will teach me to read the post properly!!!
                  Yes I am using the standard E-Sky ESC.
                  James.
