i was warned, now i have smashed it :(
    Good call on the MCPX. If only they'd been around when I was learning, would have made the whole process so much less painful, and costly!
    It will bind to the DX8 and will do pretty much whatever the Titan can do, and you have to try pretty hard to do serious damage
    Trex 450 Pro
    450SEV2
    mCPX
    Recycloquad (tm)
    Edge 540 Foamy
    AXN Floater Jet
    MDC F-14 Tomcat
    Depron BAE Hawk
    www.thedailymice.com
      Originally posted by rob12770 View Post
      it will only cost £26.42 to fix,
      I'll settle for that everyday of the week with crashes.
        cool, i saw this video regarding the MCPX
        i will try and convince my missus ..he,he..
        Trex 450 FBL
        Mcpx V2
        Foam plane sports Cub S
        Spektrum DX6I
        Phoenix sim
        Tarot 250 Quadcopter
          hell yerr Tim my last bill for repairs for my 4 helis was just shy of £500 £26 is a stroll in the park LOL
            some of these repair bills are crazy, you guys got real helis ? lol ..
            i think i will stick with the titan.. realativly cheap to fix..
            Trex 450 FBL
            Mcpx V2
            Spektrum DX6I
            Phoenix sim
              ...and im sure there was a point when we first started, when we all said that!
              Unfortunately, you get addicted.
              x 3
                knowing what i am like, im sure i will end up the same
                Trex 450 FBL
                Mcpx V2
                Spektrum DX6I
                Phoenix sim
                  hi rob, bad luck mate, but don't give up. I crashed my titan a few times, had quite a few new bits, it's just something that has to be taken into account with this hobby im afraid, is your tail boom alloy? i had a blade strike on mine and managed to straighten it with a shotgun cleaning rod and then tightened the blades so they don't flop about. have you bought a flight sim yet? my advice would be to practice on one first rather than just go out and buy an mcpx, you'll just crash that too. another tip i found with the training gear, get some thicker rod to slide over the top and this will help stiffen it up a bit. good luck.
                  traxxas bandit
                  quark sg
                  freya
                    Sorry about the crash fella. Have you calmed the controls down using the radio?
                    Read up on dual rates and expo to calm down the cyclic response.
                    And dialling in a begginer throttle and pitch curve so that when you get nervous and slam that collective stick back to zero the heli doesn't bury itself in the ground!!
                    A 'normal' pitch curve has around 3 degree negative pitch at bottom stick which you don't want as a beginner learning to hover. Maybe 0 degrees or +1 so that if you slam the stick back in a panic it should float down.
                    Once you get into forward flight you need to go back to a normal curve or you'll find it difficult to lose altitude due go the translational lift (passing thru the air gives you more lift).
                    Hope this helps,
                    Matt.
                    Align T-Rex 500GF | DFC | Beast X
                    E-Flite Blade mCPx
                    Spektrum DX6i
                    Phoenix Sim
                    • #25
                      And it was Bill Gates who said 640K memory is more than enough for everyone !! LOL
                      Raptor 30V1 Maverick Head
                      OctoCopter
                      Futaba 14SG
                      • #26
                        i have mastered fixed pitch on my 120sr then went to fly my trex 450 and smashed that up in a matter of mins,so i got a mcp-x too learn collective pitch on which can take a beating lol and fixed the 450 but wont fly it till good enough on the mcp-x.
                        • #27
                          You are not alone Rob, we were all newbs at some point, here's my video of my 2nd ever flight with my T-Rex 450 Sport, I have probably crashed about 6 times in total and now I just chuckle when I do (-:
                          Keep trying mate but one of the most important things is to make sure your helicopter is really docile, we can help if you unsure of the settings.
                          Current Fleet,
                          • #28
                            Rob me old son, it's the name of the game buddy, "Helicopters", with emphasis on the "HELL" bit. I've done soil hardness tests over the last year so often I'm thinking of going professional ! The average bang for bucks with my 450 is around £20-£30, seems to be never less. Last one was during an air test after a rebuild, one minute into the flight and "Buggerit !", dropped like a stone from 30 feet up in less time than it took for me to hit throttle hold . Guess what ? Another £20 worth. Do I want to continue this insane pursuit of the holy grail ? You betcher arse buddy. Spend and enjoy brother, there ain't no pockets in a shroud. Good luck.
                            Trex 450 SEV2.
                            • #29
                              my best crash was learning inverted, dumb thumbs when full positive pitch, hell sounded like it was digging it's own grave, very nasty.
                              Current Fleet,
                              • #30
                                ouch.. i can imagine iceuk..
                                thanks guys
                                Trex 450 FBL
                                Mcpx V2
                                Spektrum DX6I
                                Phoenix sim
