hi guys.
i have fitted a gy520 following this guide
Futaba GY520 Programming Basics - Part 2 - YouTube
but the trouble is in rate mode when i spool it up it piros wildly to the right (tail in),
in hh mode its fine.
any ideas guys i've checked everything the right way around if when its piroing i give opposite tail it spins wildly right until i release it then goes back spinning right?.
i cant get it to hover in rate mode is that the best way to learn in also?
thanks
thanks
x 3
. To sort your issue you need to adjust the tail so if the Heli is piro'ing right you need to put in 6/7 degrees of left rudder to counter that, i can't give you exact lengths because you will need to make fine adjustments but 6/7 degrees is a good starring point.
