Hi
Got a new problem with my heli to solve i am running a sc36 mk11 ringed engine i have been restting all the trims today after rebuilding most of the head assembly the problem is the engine has developed what i can only explain as a miss fire. I have tried screwing the needle valve both in and out i also turned down the slow throttle adjustment screw to try and reduce the amount of unburnt oil from the exhaust. The engine has only seen half gallon of fuel since it was fitted,the fuel is Duraglo 5 with 20% caster oil
Kev
Kev
