Crash
  • Crash
    Flying this morning doing realy well , then engine just started to loose its punch on a down wind turn of all places , not a good place. Managed to turn back towards me and the Rappy was about 15 meters off the ground and sinking . Some how I landed it but it tipped over and bent the fly bar ,Bugger me . Got off lightly I think , big rock about a meter away from it to . Very lucky appart from the audience that had acumulated very embarising .
    Regards Jamie
    REGARDS JAMIE
    Knight 50,50 hiper,hatori pipe,gy401+9254,ttcarbon blades futaba ff7fast 2.4 ghz set up with 3152 digi s all round and a rev loc 10
    450 rex standard setup
    Phoenix sim...
    Plus two gliders and one pits special biplane
    When you are back in the air, check your mixture settings, as if it is too lean it will cause the engine to overheat, and loose power. Sounds like you got off lightly, but remeber to check all of you shafts (main, tail and feathering spindle), and make sure you give the blades a good look too, espeacly if there woodies as the can crack under the covering, and the last thing you want is a blade failure with an audience.
    And a DX8 too
      Glad the damage was not too bad.
      I've got a perfect flying record - I've not left one up there yet!
        Was back out tonight and the engine is still lacking power and un predictable even though i adjust all the perameters on it , its a toki 40 with tuned pipe . Think ill ditch it if it wont behave and up grade to 50 class. Engine has only had a gallon of fuel through it , might check the plumbing in and out of the tank before im to hasty. . Thank s for the advice though
        REGARDS JAMIE
        Phoenix sim...
          Also want to be careful if the engine is running too lean as I did that on my 50 hyper and all power just seemed to drain away when I was flying it and next thing I heard was a loud POP sound and then nothing from the engine.
          Turned out that it ran to lean got way too hot and popped a lovely hole in the piston!!!!
          Trex 600n - Yeah bring it on!!!!
          Hyper 50 engine
          Align GP750 Gyro w/9254
          Futaba FF7 Tx 2.4 jobby now
          Flying since May 2006. Crashes so far: 2 and the 2nd was a fatal one!
            yeah hypers just love to do that.
            All the best
            Tony.
              But at least they're dirt cheap these days - £99 from kevs racing bits
                yeah but they don't come supplied with quick release bolts
                All the best
                Tony.
