Maiden hover on Flasher 500
  • Maiden hover on Flasher 500
    So my Flasher 500 arrived in the week (a Trex 500 ESP clone for those interested), complete with metal carry box, pitch gauge, GY401, Hitech 5245MG servos, DS520 tail servo and training gear. I had previously bought a DX8 transmitted / receiver pack so had everything I needed.
    I had promised myself it would take me a few weeks to strip, reassemble, check, double check, triple check everything before her maiden flight. However, after a few late nights, head scratching, and then some careful programming, wiring and adjustment suddently found myself this morning with my Flasher ready for her maiden in the back garden.
    Only problem was that I was still waiting for my batteries to arrive, so decided to use 2 of my 3S 1800 20C packs from one of my many RC cars - in this case a 1/16 scale E-revo VXL. Sure, these packs are somewhat underspecced for what i really need but I figured that i) I could not wait and ii) it was only going to be some lazy hovering in the garden - and how many amps do you need for that.
    Needless to say, got the Flasher hovering nicely after dialling in a little trim from the starting positions on the tail, and cyclic - which was not too far out. Took me a little while to get the gyro set up nicely.
    I am feeling totally on a high. Not only have I managed to hover the 500 nicely on a couple of sets of packs (have spent lots of time on Realflight over the past 2 years), but am also feeling very pleased with myself considering that I know nothing about helicopters in the real world (only what I have read), and had nobody to help me set her up. It just shows that if you are careful and take your time learning on a sim you can have some successful time in the air without being in a club - something I tried to join but my local club is totally full and has quite a waiting list for new members.
    This first hover has shown me a few things and I learned a great deal already just from those 10 minutes in the air. Got some minor adjustments to make, plus a whole load of confidence to build before I try forward flight (which I think I am capable of doing).
    One question though (and sorry for the droning on, it's just that I am still on a high). One thing that totally caught me by surprise was the fact that the rotors would spin up at zero throttle -despite my throttle curve being at 0% at zero stick. It is only having throttle hold on that stopped me getting my arms chopped off. Is this normal, or did I set something up wrong?
    Thanks for reading this far - appreciate this is probably a little dull for some people.
    Steve
    Trex 500 ESP
    Trex 450 Pro
    Trex 250
    Blade 130 x (2)
    Brushless nano
    Congrats on your first hover m8, and I completely understand the great buzz it gives you
    As for the rotors spinning up at low throttle despite having a curve set at 0% at low stick, well the first thing that comes to mind is you may have the tx idle up switch in the wrong position.
    This of course is assuming you have programmed an idle up throttle curve in the first place.
    Graham
    Phoenix, DX6i.
    x2
      What Esc are you using? Have you programmed the ESC to learn low and high throttle?
      Eddie
      Velocity 90 FBL BeastX V3
      Trex 600 LE FBL BeastX V3
      Trex 500 EFL Pro BeastX V3
      Fusion 50 FBL
      VBar
      All powered by a DX8
        Hi, the ESC is a phoenixtech 75A that came with it. The idle up settings are programmed, but not in use - everything is selected for the dumbed down settings that I have created on position 0. I'll re bind the transmitter, and re learning the ESC settings to see if that solves it. thanks.
        Steve
        Trex 500 ESP
        Trex 450 Pro
        Trex 250
        Blade 130 x (2)
        Brushless nano
          i had a similer problem when i changed my esc on my trex.. need to set the soft start...
          RAPTOR 60
          TREX 500 CF, FBL
          MSR-X
          JR XG7
          __________________________________________________ ______________________
          http://www.hdrcmc.co.uk/index.htm
            Not the same buddy.. he's getting throttle at 0 stick.. need to go over the programming!
            Eddie
            Fusion 50 FBL
            VBar
              Dope
              Didn't read all the tread sorry...
              RAPTOR 60
              TREX 500 CF, FBL
              MSR-X
              JR XG7
                Sounds good. Bring it along to Kol's indoor meet at Totton if you're in the area this evening 7.30 - 9.30
                http://www.rcheliaddict.co.uk/south-...tml#post599822
                  If that doesn't fix it, setting the travel adjust or throttle curve to -5 at low stick on the Tx should sort it out.
                  Remember, you need to learn how to turn before you start moving forward too fast
                  Call me Matt
                    you should have a CD with the box, check the New phoenixtech SR75A esc manual, we have recently upgrade the stock ESC from hobbywing 60A to a ''German'' ESC, which we call it SR75A, it has a on/off switch.
                    andy
                    The UK's sole distributor of MKS Servos
                    www.mks-servo.co.uk
                    We are here to listen and support heli community
                    regards
                    andy jiang
