Mixing problems Swift
  • Mixing problems Swift
    I have just built my nice new Swift GREAT! And now comes the problem , when I move the left stick (Eleve) forward and back the swashplate tilts (YOU GUESSED IT) forward & back,now on the right stick(Aile) the same movement moves the swashplate up & down ! Now I figure I need to alter the mix settings on my JR to sort this !? I presume they are both doing what each other should be doing only the wrong way round can anyone help please ??????????????
    Hi Ed
    Umm sounds like you got mode 1 setup?
    Well I fly mode 1, and left stick is Elevator and rudder,
    right stick is throttle/pitch and aileron.
    So when you move right stick up n down thats controlling your pitch so swash will rise and fall, as mine does
    Is this correct ?
    Dave
    T-Rex 500ESP FBL Beastx
    T-Rex 450SE V2
    Futaba 7c 2.4ghz
      Hi Ed you may find the answers you need on www.swift-tuning.com you will find this very usefull.
      Steve
        specifically covered in this article :
        http://www.swift-tuning.com/setup_swift.php
        Sponsored by CSM, Optifuel
        Your RC Heli World
          Sorted now thanx for all the advice !!!
          cheers again !!!
