Advised to get Ball link pliers, was given this link:
Fast Lad Performance
Started assembly yesterday went to use it for first time and it does not fit the linkage balls .. the slot which you would use to fit behind the ball when using pliers for ‘fitting’ the link is not big enough ... it physically won’t go behind ball.
Is there a different size required for 50 Heli’s ?
Build is TT X50
Build is TT X50
