what would you do about your belt??
  • what would you do about your belt??
    Hiya all.
    Every time i post on here its a question i know!!
    Can anyone tell me if they have run there helicopter with a belt that has 3 teeth (for the lack of a better word) missing on it, They are all missing in the same spot . It seems to fly ok but i have ordered a new.....
    What kind of tightness should it be..ohhhh and ive been using a little wd40 on the gears and belt at the back, should i stop sparying the tail gear with wd40???
    ohhhhh one more thing how long should a belt last?????? in hours if poss....
    Does anyone here have a perflight routeteen that you what to sure with me???
    i.e greese this and tighten that>>>>>
    many thanks
    james
    Originally posted by notscratcher View Post
    Hiya all.
    many thanks
    james
    sry i didnt say this is all for a trex450se v2
      If your belt has teeth missing don't fly it - wait until you replace it!
      When it fails (and it will) it will result in a lot of damage which could be avoided cheaply and easily.
      I use Pledge polish on my belt but I have heard of WD40 being used. I was concerned about WD40 damaging or rotting the rubber in the belt.
      IMHO, A belt at the correct tension should last ages (years maybe). Unless you crash of course
      As well as a general look over the heli, I tend to check the links for any looseness and also check belt tension as that changes with the tempreture.
      Cheers, Lee.
      Proud recipient of an EGS
        That was very informitive thank you....
        So no flying today then
        thank you
        james
          What about a few teeth missing off the main gear? Maybe, 5 teeth in the same spot? (Trex 450SE)
          Sound horrible, but is there much of a danger? The only thing I can think of is possible engine damage, as the motors little gear might rev each time the missing teeth come by, but the momentum of the blades should stop that happening as the gear wouldn't slow enough to cause a problem at the point the teeth aren't 'biting'?
          (Please don't ground me! Parts are arriving soon!)
          Blade CX2 - With AR6100
            The teeth are missing from the belt not the main gear.......as for the main gear i would buy a new one!!!
              Sorry notscratcher. You're query about the belt is answered. I have a similar problem, except the teeth are missing off the main gear, so was hoping someone could tell me if I am grounded as well.
                Cralis
                Again, don't fly it!! Replace the main gear before your heli lands you with a bigger bill!
                The motor revs will rise considerably while it is in the "gap" on the main gear putting a load of stress on the next availible tooth until that one comes off and the next one and the next one etc.
                Cheers, Lee.
                  If any parts are worn or missing bits DONT FLY IT. Simple
                  Velocity 50
                  Synergy N5
                  Fury 55 FBL
                  Trex 700
                    I agree
                    The gap in the main gear teeth will let the motor over rev, then when the good tooth arrives it might snap off - also it might just climb on top of that tooth and suddenly slow or stop.
                    Keep a main gear in reserve spares.
                    you will never break the part you have already as a spare. (unfortunately you will break something really strange and unusual instead).
                    This is why some people buy two complete kits, and one set of electrics!
                      Thanks guys! So that me grounded for a few days...
                      Thanks a lot!
                      Anyone on Phoenix tonight then!
                        To recap.
                        Use a silicone polish like Mr Sheen not WD40 as stated.
                        To check the belt tension, it should be tight enough that you cannot push one side of the belt against the other, but not so tight that it wont move with a little pressure. (You check this where the belt goes over the pully just behind the main gear before the tail boom.)
                        Mark
                        sigpicx2
                        Airskipper 50 - For sale
                          They make gears and belts with a full set of teeth for a reason.
                          Allan
                            Looks like im grounded until tomorrow (come on hurry up mr postman)
                            I hope you all have happy flying this evening....
                            i hope the weather holds out for tomorrow evening
                            thanks james
                              Whatever you order after a crash or whatever you call it, order two, one for the heli, one for the tool box ! or have two helis !!
                              Martin
                              Fly today, tomorrow it may be too late !!
                              http://www.ukheli.com for my T-Rex 600e / 600n build site
