How similar are the Mini Titan and Trex 450xl...
  • How similar are the Mini Titan and Trex 450xl...
    ... from a setup point of view?
    The reason I ask is that I am struggling to setup my mini titan correctly with my DX6 radio. (I am fumbling fairly around blind here.)
    I have just found a link which shows the full set up for the 450xl : http://www.rcuniverse.com/forum/m_3815284/tm.htm
    Obviously I would LOVE it if I could just use the above guide to make this pile of plastic and wires noob training gold; but I dont know enough to know if this would be appropriate. Are the servos placed in a similar way, and would the settings recommended be advisable?
    I know this is unlikely to be a short yes/no answer, so I really appreciate the help. I am completely stuck as it is. Thanks in advance...
    Yes it will help you out with setting the eccpm, the servo are fitted different on the trex than the titan but the set up eg: servo settings are the same, just take ur time
    MK HELI CLUB WEB SITE
      Hi John
      Did you buy the kit or the ARTF model,
      I did, and it was a just a case of assemling the electrics, Tail and set up.
      Did you buy it from a local shop, I did with mine, and once I finished I took it back to get them to check it over, (had set the ESC wrong, due to being hard of hearing, i miscounted the beeps LOL)
      The blades needed balancing, which I did and I have now flown (hovered moved around) it in the garden
      Keep at it, I like mine, and cant wait to get better at flying it
      Roll on calmer days
      TDR (in progress)
      SAB Goblin 700
      Vibe 90SG Vibe 500E
      Kalt Baron30
        I bought it as a kit, as I like assembling things.
        First up is setting the tx, then I am going to duck tape the heli to a table, and work on getting the swashplate and all the servo arms level.
        Glad to hear you are hovering - any videos?
          do take a look at the trex450,hdx450 and dragonus build stuff in Finless bobs tech room at helifreak.com
          No mini titan build stuff there yet though.
          http://helifreak.com/forum-95.html
          I big help to understanding how small helis work.
            If the wind dies down i hope to strap a little cam to it, and we will see. I am just setting up the head speed, have got a tacho on it, just need to get a chance to check it out.
            Will keep you informed.
            TDR (in progress)
            SAB Goblin 700
            Vibe 90SG Vibe 500E
            Kalt Baron30
