SpyHawk / receiver wiring
  • SpyHawk / receiver wiring
    I have acquired a Spyhawk (4ch, with 6ch receiver) that has been partially dismantled.
    Need to find out which way to plug the connections into the receiver !
    Receiver has six 3 prong pins (1 to 6 from the bottom up?)
    There are four 3 pin connectors to plug in, inc one from the main motor controll board where the battery power comes in
    All are white, red, back from left to right (or vice versa if I plug it in the other way round)
    I could probably work out the two servo and tail? ones go
    but desperately need to know which way to plug in the main motor / power one
    Anyone any ideas
    or have a SpyHawk they could examine for me
    Other similar models are probably wired similarly
    Update - The Piccolo, which has a wiring diagram on swashplatete.co.uk, seems to use broadly similar wiring
    Throttle/motor to channel 3 ? with earth side on the rhs
    But any confirmation anyone else could give would be much appreciated
