Lama, TX and crazy servos
  • Lama, TX and crazy servos
    Hello!
    Raptor not arrived yet, and a broken skid on ther Trex, so I decided to repair my Lama whihc had sripped gears. All done now, but when I switch on my TX, then switch on the Lama, the servos all go crazy...
    I have had this TX working with the Lama before (Hitec), but not sure what I have done since last time it worked.
    Am I right with these settings:
    PPM, Normal Swash?
    Not sure what else can cause this...
    I must be on the right channel. If I switch on the Heli without the Tx on, the 4-in-1 box flashes, gyro arms, but then it flashes green/red, meaning no Tx signal. When I switch on the Tx, the servos go ape...
    Blade CX2 - With AR6100
    sounds like your getting interference or maybe not switching the tx on before the heli or... having the airial all the way down on the tx. it happens to me all the time.
      Nope. I got the aerial out full... staning right next to the Lama. Same thing. I'm sure I had this before, but can't recall the cause, nor the solution.
      I *think* my Tx is setup correctly...
        I'm a monkey... I had the channel number on the Spectra Module on the back of the Tx set to 66, instead of 65! Put it to the right channel, and we're all OK now...
