Optic 6..
  • Optic 6..
    HELP.. i have a hitec optic6 transmiter and would like t adjust the (d/r)duel rate and the(exp) exponential contol BUT cant seem to get into the menus to do said task i was woundering if any one could help me??i could do with simple advise MAYBE its ME doin something wrong!!!
    Well the manual says this about dual rates...
    You can use the dual rate function or the exponential
    function to reduce the aileron and elevator travel in flight by
    flipping switches. Dual rates are typically used to reduce a
    model's sensitivity and cut down total travel. Exponential
    functions make the response slower around center and
    larger away from center.
    You can use both but they are activated by the same switch.
    You may wish to use Dual rate on one side of the switch
    and exponential on the other.
    48. Aileron Dual Rate setting. Get to the D/R menu by
    pressing one of the Up Down Edit buttons repeatedly until
    D/R appears, as shown.
    49. The aileron dual rate setting automatically affects both
    ailerons if the flaperon function is active. To set the aileron
    dual rate, move the arrow by pressing the Right Cursor
    key until the little arrow is under or over the numeral 1 (the
    arrow depends on the position of the Ail D/R switch above
    the right stick. Now move the aileron D/R switch up or
    down, noticing the position of the arrow. You can set two
    dual rates, one for each switch position. If you set them,
    be sure to note which switch position turns them on.
    50. By pressing the Data +Increase or -Decrease keys, you
    can add or subtract from the numerical value displayed.
    Note that you may pick a value anywhere from 0% to 125%
    (125% is larger than the normal amount, so if you do this
    be careful not to exceed servo travel limits and cause
    stalling or excess current drain). If you quickly want to get
    back to the default 100%, press the Clear key. We suggest
    using an initial value of 75%.
    The manual and a turorial can be found here:
    http://www.hitecrcd.com/Support/Manu...Manual%202.pdf
      And this about exponential:
      1. Enter the programming mode by pressing the two Edit Up
      Down keys (the two keys on the far left) at the same time.
      Press either Edit Up Down key until the EXP menu appears,
      as shown.
      2. To set exponential for channel 1, move the arrow by pressing
      the Cursor Right or Left keys repeatedly until the arrow is
      over the channel number you want. Now switch the
      appropriate switch up or down, noticing the position of the
      arrow. You can set two values of exponential, one for each
      switch position. By pressing the Data +Increase or
      -Decrease keys, you can add or subtract from the numerical
      value displayed. Note that you may pick a value anywhere
      from -100% to +100%. If you quickly want to get back to the
      default 0%, press the Active/Inhibit (Clear) key. You should
      understand that you won't see changes in your model's servo
      response unless you move the sticks. To get a feel for how
      exponential works, just hold partial stick and switch the Expo
      on and off (one side of the switch should be set to zero expo).
      You'll see how it affects the servo travel.
      3. The values you set for exponential are highly dependent on
      both the model and pilot's preference. I normally recommend
      a start value of about -10% to -20%, and many test flights,
      slowly increasing the number until things are "right".
      Obviously this depends on the pilot and model so go ahead
      and fly it with Expo only on one side of the switch, turn it on
      and off during flight, and change things to suit yourself. Or
      don't use it at all if you don't like it - it's not for everyone.
      4. Repeat this procedure for the expo settings on the other
      remaining channels.
      5. Return to the regular operating mode by pressing the two
      Edit Up Down keys simultaneously.
        thank you for the reply.. but i have done as this says a number of times but cant get the d/r menu up,, i just want to make my servos more responsive on my t-rex( see dosile t-rex post)
          Well maybe you just need to increase the end points... but....
          To access the D/R menu, I beleive its the same as expo above:
          Enter the programming mode by pressing the two Edit Up Down keys (the two keys on the far left) at the same time.
          Press either Edit Up Down key until the D/R menu appears as shown.
          Hope this helps...
            yea i have just held both down and scrolled the menu but still no d/r is it ME???
              Do you get any of the menu options when you hold the edit keys down?
              You have to press and hold them...
              Do both keys work otherwise? Perhaps one of the is bust?
                i get ,,model sel,,reset..time,,mode,,ppm,,sft.n,,copy,,120',,he li,,and model name(t-rex-1),,
                  I think your holding them down and then turning it on right?
                  You should turn it on, then press and hold them both afterwards. You are getting into the system menu instead of the main menu I believe.
                    It should be around EXP,REV,ATV in the menu system.
                    Raptor 50 V3 Titan
                    Trex 600N Pro R.I.P
                    Knight 3D
                    Trex SEV2
                      Correct.
                      Gazza
                      Stainburn Heli club
                      Trex600LE
                      Radix blades
                      Align DS610's on Cyclic
                      Spectrum DX7
                      www.aurorra.co.uk
                      www.fast-lad.co.uk
                        I Am A Dumb Ass!!!!!!!!!!! Thanks Guys,,, WOULD 50%BE OK DO YOU KNOW??ITS SET AT 100%!!
                          50% what?
                          If you mean dual rate, then 50% will give you half the movement you had at low rate.
                            No less than 60% is ever recommended on dual rates, I never saw the point of it with helis anyway. Suppose it depends on how much of a panicker you are
                            Surprised you never got a thanks for all that cracking info Jim
                            Gazza
                            Stainburn Heli club
                            Trex600LE
                            Radix blades
                            Spectrum DX7
                            www.aurorra.co.uk
                            www.fast-lad.co.uk
                              LOL - all part of the HeliAddict service
