Help Please
  • Help Please
    Ive brought a Futaba t7cp ff7 and im trying to figure out what setting's i will need on the tx for my Twister 3d storm,
    Swashplate Type?
    Mixing Setting's? can i use the setting's in the heli manual for the 9cap
    Any other settings i might need to change because ive reset the memory in the tx so im starting a fresh.
    Twister 3D Storm
    Eflite Blade msr
    PKZ P51 Micro Mustang
    Phoenix
    DX6i
    Hello, I think that tx will allow you to select HR3 or possibly SR3 (120° cyclick servos).
    HTH,
      Hi,
      I don't think you will need mix.
      But - and I don't know that heli - when you select a swash type that isn't exactly right you can reverse some servos to get it to work properly. Especially CCPM swash plates.
      It's quite often a case of fiddle until it works.
      Best of luck.
      David
      Happy Landings.
      David
      Raptor 50. OS50
      Mcpx
      Blade 130x
      Goblin 500
        Thanks yeah the options on the tx are h-1 h-2 he3 hr3 h-3 hn3
        ive reversed the servo's as the manual for the 9cap
        Twister 3D Storm
        Eflite Blade msr
        Phoenix
        DX6i
          yes it is a 120 swash so you will need to select HR3 and yes you can use some of the info in the manual for the FF9 i dont know this heli well although i have flown one once
          to get a better understanding of what you are doing i would strongly recomend looking at the vid here
          Trex 450 SE and general build videos are here - HeliFreak
          and look at CCPM part 1and part 2 also Pitch and Throttle Curves
          also if you do as much as you can i would still find a model shop near you to get it set up right this will save you time and money
          http://www.jperkinsdistribution.co.u...s/6600090b.pdf
            reversing the servos on the tramsmiter per manual will not mean it is 100% right as you may find the servos are working in the wrong direction the ccpm vids will show this and how to sort it
            there is quite a few clubs near you so may be getting in contact with some one from one of these may help you as well also the guys on here
            http://www.bmfa.org/clubs/clist.php
              Thanks everyone ive now got it setup as the manual for the 9cap so im gonna have a go tomorrow to see if everything works as it should
              Twister 3D Storm
              Eflite Blade msr
              Phoenix
              DX6i
                remember on the storm you pull down on the swash plate to get positive pitch
