Hello
I'm building a Dragonus II helicopter.
I've got a Spektrum DX7 radio. Now I've only flown a fixed pitch Honey Bee helicopter which I'm flying reasonably well.
I'm spending plenty of time on the Phoenix simulator with the radio before I attempt to fly the Dragonus. The kit has not arrived yet anyway so I have plenty of time.
Channel 1 controls throttle, channel 6 collective pitch.
Now can you tell me if this procedure is correct for a real helicopter. It works well in the simulator but I'm not too sure. I've deduced all this for myself and nobody has shown me the correct procedure so I'm sure I might be doing something slightly wrong.
I've found that if I leave it at the default setting - throttle goes from 0 to 100 and collective goes from 0 to 100, I can not hover upside down because the throttle drops too much.
So this is my procedure
1) Set the throttle so that the minimum is 25% and max is 75%
2) Set collective so that the minimum is 0% and max is 100%
3) With the throttle stick at bottom, turn on throttle hold switch so that it spins up to 25%
4) Now fly the helicopter as usual
Is this the correct setup and procedure for a real helicopter?
I'm using a linear throttle and collective curve, I'm not ready for advanced throttle curves just yet. Although I do realise a linear throttle from 25 to 75 is technically a curve.
Also I think I should be setting throttle from the radio itself and not the simulator since I'm going to need to do it that way with the real heli right?
