worried about my new lipo
  • worried about my new lipo
    hi
    i just bought my new lipo battery nothing speicial just a 7.4v one. it came with the wrong connector so i orderd the correct connector. the problem was when i cut the old connector off the battery. the battery began to get very hot this worried me so i put it in the garden have i done something very wrong here i am very confused
    When you cut the old connector off did you cut thru both wires at the same time,
    Id guess you have shorted your pack and would think its now scrap
    Gaza07
    Trex 500esp 6s Beast-X V3
    Trex 600esp 12s Beast-X V3
    A few Multi Rotors
      Yes I guess you shorted it out - if it's not puffed out measure the voltage and if it's above 6V have a go at recharging it but do it in a saucepan so you can contain any spew and needless to say if it gets hot, starts puffing out stop immediately - if its puffed its history
      John
        oooo dear i am such an idiot yes, i did cut them together looks another £15 needs to be spent
        thanks for you replies
          hi,
          i have found a voltage meter in the shed but i dont no what the dial should be on and which holes to plug the sticks into. im very confused on what im doing
            also can anyone recomend a good 7.4v lipo. preferably with a jst connector already attached
            thanks again
              can anyone help me here?
                Is this for the twister bell 47 have you checked out ebay see there are any good deals
                Gaza07
                A few Multi Rotors
                  http://www.jperkinsdistribution.co.u...s%20and%20accs
                  I use these from Perkins, good value from you LHS..... £14.99
                  Fly today, tomorrow it may be too late !!
                  http://www.ukheli.com for my T-Rex 600e / 600n build site
                    all the battery's on ebay are from HK and take ages to be deliverd. and i find the jp battery expensive for what it is. the batery i just blew cost me £12 and it was 1000mah rather than 800mah
                      Inwoods are normaly hard to beat on price have a look there, Altho the price you payed is very good,
                      There was a company around a while ago called Maxpoly had the 800mah packs for just over 7 quid but they seem to have disapeared
                      Gaza07
                      A few Multi Rotors
                        yer i saw them on ebay. the company i bought mine from was electrolite from ebay but they have disaperd to. guess i will just have to wait
                          just found this one on ebay but it has a very low c rating(8c) what does the c thing mean?
                          http://cgi.ebay.co.uk/New-7-4v-8C-13...QQcmdZViewItem
                            The C rating on a lipo is its capacity so if you have a lipo 800mah @ 10c it will deliver 8 amps without damaging the pack
                            When it says charge at 1c this mean you would charge it at 1 x capacity = 0.8 amps or 800mah
                            Hope that helps ya
                            Im not sure how many amps a twister bell 47 pulls but id guess around 6 to 8 but some one may have measured it
                            Last edited by Gaza07; 24-12-2006, 12:19 PM. Reason: ooops i put the wrong figure down doh!
                            Gaza07
                            A few Multi Rotors
                              C is the capacity of the cell - 8C means you can discharge it at 8 times its capacity ie an 800 mAh cell can discharge at 8 x 0.8 = 6.4A. 1C charging means you charge it at its capacity for 1 hour eg 0.8A in this case. An 8C cell should be fine for the Twister 47 or Medevac as they discharge at about 3A.
                              John
