After getting the cylic and swash sorted, balancing blades and paddles and making a new drive shaft from some solid brass rod I now have a beautiful smooth rotating heli without cyclic drift fore and aft - my initial orgasmic delight and lift off was curtailed by the waggle of tail - which I hadn't had in previous adventures. I've centred and 90 degreed everything, checked ATV to ensure no servo binding. I have aHelibee gyro into Futaba 6 Super with dual rate lead going into channel 5. ATV on rudder about 30% and ATV on the dual rate chennel at 50% as per gyro instructions. No creep at rest but spooling up above half throttle starts the waggle - any ideas ? Thanks.
PS All throttle related tail rotor compensation inhibited.
