Having recently dumped the Twister into the ground, I am now nearly at the end of the minor rebuld required,
Having set up the servos mid stick, I have now reconnected the motor so I can set up the blades and pitch.
I have a small problem, when I connect the battery pack the ESC bleeps once to indicate "brake on", but I cannot get it to arm,
have checked settings on the radio, but cant seem to get it to arm
any suggestions anyone.
ESC is the 25a Twister one for the heli
Batts are 1500mah Li-pos
Receivre is Sanwa RX831 PPM
Radio is Sanwa RD6000 Sport, set up for CCPM
Many thanks
Many thanks
