Hi
I've been told that using the 401 gyro with PPM mode can cause problems
giving the odd twitch or kick from the tail because the gyro does'nt like the
PPM signal and responds better with PCM,
Is this true??
All though I don't like PCM mode, because of its long signal and long response
checking time and deciding weather to go into fail safe or not before it switchs back on, were as with PPM you just get a glitch,,
Is it worth changing my RX to a PCM?
Is this true??
