Hi
doe's anybody know the default factory adjustment for the idle screw on this
engine, and which fuel it runs best on,
The engine is in my new/old F1 carbon max which fly's realy nice (when it doe's fly) but I can't get it to idle ok, the clutch is a bit grabby so I need a steady idle.
The Super tigre manual say's four and a half turn's out for the needle valve as
a start point and says the idle screw is set from the factory,
Thats all fine and good if you, or someone else, has'nt touched the adjustment,, does'nt help if you need to start from scratch, ie. different fuel,,
it goes on about doing the pinch test etc to get the settings right but thats
on a plane and I can't run the heli at full throttle and pinch the fuel tube
for obviouse reasons,
I know its an old engine but also know it has'nt had alot of flying time and
I don't think it needs a new engine, just the right setup, and a bit of TLC and I'm sure it will be fine.
I've e-mailed the ST web site,,, but no help!!
so if anybody has used or has an ST 61,,
any advice or tips would be Appreciated
