Lipo Charging advice Help!!
  • Lipo Charging advice Help!!
    I may just be being thick here but.. I am using flight power lipo batteries for my Robbe L-16 these are 3s2p 11.1volt 5000mAh. Now, I came to setup my charger for these last night (I use a propeak constellation charger) I set the charge to Li-po 11.1 Volt 5000 mAh with a charge of a max 3.5amps as recomended in the battery instructions and started charging.
    While the first battery was charging i was reading and noticed on the flightpower instruction sheet that the "charge volatage" should be a maximum of 4.25volts. when i looked at the readout on the charger its was just going up through 11.4volts!! Not being sure a was right i switched the charger off!!
    can someone put me right on this please??
    I am running 11.1volt 1800mAh Lipo's on my t-rex and have always charged them with a set up of 11.1volt 1800mAh at 1.8mAh charge and been fine, now I am not sure if that is correct. Help please
    the 4.35v is per cell in series. So your 3s pack is 12.75v maximum when charging
    Ade
    www.accurc.com
    adrian@accurc.com
    This is an apple free zone
