Raptor 30 v2 THRO HOLD and CUT
  • Raptor 30 v2 THRO HOLD and CUT
    Hello everyone !
    Wanted to ask you something, just couple of minutes ago i have tried and tested my new Raptor 30 v2 (hands still smell of Nitro, my first Nitro Heli) and have a problem. When i started the engine full stick down i noticed that i have to hold my blades quite hard from stopping them spinning... well that doesnt sound right dos it on full stick down?
    I am using DX6i Spektrum (installed it yesterday) What can be wrong can you please help me out guys im sure the blades not supose to spin that hard maybe ive done something in settings wrong or not correct what is the right settings from stopping this?
    Secondly lol the TH HOLD is not working ether same as Throttle cut. Well it does work in some way like if i move the Stick up a little from the Lower possible position it will move the servo that connected to engine to minimum position. Is the settings wrong again and how do i set this up as to stop the heli i had to hold the fuel tube to stop fuel pumping in to the engine and cut it off before it does my hands.
    Very appreciate your time and help !!!
    Regards,
    From London, Sergey
    Fly with the best - Die like the rest !
    - T-Rex 600 Nitro Pro
    Raptor 30 v2
    Blade 400 3D
    DX7
    Originally posted by s007 View Post
    Hello everyone !
    Regards,
    From London, Sergey
    Get down to the local club and they will help you with the final set up
    Throttle hold leaves the engine at a set tickover point
    Throttle Cut Cuts the engine
    Mark
    www.uavaerialservices.co.uk
    BNUCs - Operations certified
    CAA - Permit for Aerial Work
      Disc - I would gladly go to a Local Club but i cant really call it a Local as it at least 15-20 Miles from my house as i live in Central London and dont have my own transport yet.
      I know what those switches suppose to do but i need help with the correct setting for them even from anyone will do if you can tell me all the setting from your control regarding to what is responsible for them and i can set them up on My transmitter.
      Sergey
      Raptor 30 v2
      Blade 400 3D
      DX7
        Hi
        I have my Throttle end points on my DX6i (with Raptor 50) set to 100% at the top and 70% at the bottom. This gives me a nice idle without engaging the clutch. These settings are in the 'Travel Adj' menu.
        The Throttle cut is activated in the 'Thro cut' menu and should be set to 'ACT'. When the Throttle cut button is pressed, the servo should move to its lowest point and cut the engine. If it binds, adjust the length of the control rod until the desired position is reached.
        Mark
        sigpicx2
        Airskipper 50 - For sale
          Cheers mark ill do it now i guess i do need to extend the rod to cut the engine.
          Raptor 30 v2
          Blade 400 3D
          DX7
            Sorry by the way lol might sound funny but which way is to close when throttle cut is activated when looking at Raptor from the Muffler side to cut engine is the rod moving towards engine or towards servo? Like does the thing suppose to open the engine when moved or close it?
            Regards,
            Sergey
            Raptor 30 v2
            Blade 400 3D
            DX7
              If its a ThunderTiger engine then look at the carb arm. It will move out to open the hole and let more air in which means its going to full throttle. Obviously when the arm moves in then its closing the throttle. If its an OS engine then looking from the muffler side the marking to the right is zero throttle and the marking to the left is full throttle. Obviously half throttle is the middle of the 3 little marks in between the 2 mentioned above. Its pretty simple to work out really. Is your throttle trim all the way down but the helicopter blades still try to move when you start it? Have you adjusted the trim to get the motor to idle nicely? I highly recommend you get someone to look it over to be honest though or get to a club. Even if its just for someone to have a quick look at it and give you some tips. Nitro helicopters are extremely dangerous mate and if that thing goes off full chat in your hands then your gonna be in trouble.
              Lee
              Lee
              www.raptoruas.co.uk
              www.lee.rcha-uk.com
              www.gensace.de
                http://www.raptortechnique.com/ lots of good info here altho if ya not sure how the throttle works you may be heading for disaster, id also say get it set up and test flown if at all possible if not id read that lot a fair few times before starting it up again
                450 sport
                700 le fbl
                  Hi Lee, yes finally i sort it out with THROTTLE CUT it was actually fully open when i stated the engine must say it wasnt easy to hold those blades from spinning, very very lucky for me nothing happened well good lesson learned. Not sure but on the other side there is like a little thing that i can turn like some sort of adjustment thing my engine is an OS 32 .By the way what is a good % to have a TH HOLD switch at in Normal and Stunt Mode?
                  By the way what does AIL D/R Switch and RUDD D/R?
                  Thank you all for your time to reply guys! I think ill stick to this forum seems to be very active
                  Regards,
                  Sergey
                  Raptor 30 v2
                  Blade 400 3D
                  DX7
                    Th Hold should be set to your idle position and it is good practise, once set, to always start with throttle hold engaged and only released once the model is on the flight line ready for take off and you are a good distance from it.
                    RUDD D/R I've never used and the AIL D/R allows you to set up different rates for your Elevator (forward backwards) and Aileron (left right) movement of the swash plate and subsequent response of the Heli.
                    Mark
                    sigpicx2
                      Where in London are you?
                      I'm in crystal Palace and I'd be glad to look things over for you.
                      Ian
                      Knight 3D
                      Velocity 50
                        PM Sent.............
                        Raptor 30 v2
                        Blade 400 3D
                        DX7
