blade 230S
  • blade 230S
    Hello guys and girls
    Any body on here is using blade 230s if so what batterys are you using for yours.
    Thanks in advance?
    Best Regards
    Dean
    Blade 200SRX
    Blade 230 S
    Trex 450l dominator
    Trex 500 Pro
    450 Forza
    RJX Extreme 50N
    1500 Varioo scale Jet ranger (scorpion motor)
    PL6 with coolice PSU
    neXt sim
    DX9
    Dean, I guess exactly the same as you, ie stock and those I used on my 200 which in this case are Overlander 860. I doubt my batteries are in the best of health but after 5 minutes of gentle hovering / figures of 8 (ish) I'm left with better than 30% remaining.
      Friends use these in there 230
      Turnigy 1000mAh 3S 20C Lipo Pack (UK Warehouse)
      • Trex 700N RMJ,msh brain
      • Goblin 700 black thunder sport,vbar Neo
      • Trex 700L Dfc,vbar Night Flyer
      • Trex 700x,Vbar Neo
      • Goblin 570,msh brain
      • Goblin 380 kse,msh brain
      • ​NeXt sim and DX9 and Vcontrol
        As above, I am using the same as I used (use?) on my 200SRX:-
        2 x Stock 800mAh
        4 x Turnigy nano-tech 950mAh
        4 x Overlander 860mAh
        These batteries altogether have done about 6 hours 35mins (65 flights) on the 200srx and 4 hours 3 mins (75 flights) on the 230S and I am now getting approx. average flight times to 30% of 5 mins, 6 mins and 6.75 mins (respectively), although this is highly dependent on flying style & weather (temp & wind). This is about 40% less than what I was getting on the 200SRX albeit that the batteries were a lot newer then.
        I would like to try some batteries that are slightly bigger to help with the slightly aft CG but, at the moment,
        a). 10 batteries is quite enough to keep the this thing serviced all day at the field.
        b). with my current flying capabilities (circuits, 8's & lots of hovering (orientation practice) I don't notice any problems from the not quite perfect CG
        HTH.
