Vbar gyro help
  • Vbar gyro help
    Hi, I have been trying to resurrect a very old 450 bitsa helicopter and some one gave me a koala Kbar.
    A chinese clone I think, anyway I can not get the gyro to switch from HH to rate mode. Do these have to be
    set with bank switching on this flybarless system or being an old fart am I doing it wrong I have 67 in gyro switch position 0
    -6.5 in pos1 and 0 in pos 2 but it remains in HH mode. The tail goes l and r on the sticks and also when you move the helicopter
    but it never jumps to the centre when switching between the different values. The tx by the way is dx8 and I can see the values changing in monitor function.
    What i'm asking is is this a throw away or can it be made to work. Thanks
    I might be wrong here but I don't think you can have a rate mode someone will chip in if am wrong am sure !
      I have a yellow K BAR and mine only has heading hold. I'm using a DX8 too but changing the gyro gains in the tx to negative numbers does not switch my K bar into rate mode.
      Barry
      Barry
      Sutton Coldfield Radio Controlled Aero Club (SCRCAC for short!) Citizen 00182
      Two Blade MCP-x
      Two Blade 130x
      Red Bull 130x
      Gaui 200 V2 FBL with mini V Bar
      Trex 250SE FBL with mini V Bar and DFC head
      2 x Honeybee King 2's (now retired)
      Mini Titan E325 with Tarot DFC head and mini V Bar
      Gaui 550 CF Hurricane FBL with mini V Bar
      HK Cessna 182 Deluxe, Silver Lady and Graupner GF-15 EDF (just for relaxation)
      And a tolerant wife, what more could any man ask for?
        Hi, I am honestly not sure if it has a rate mode but you should not need it.
        I have setup a lots of vbar before also on my 450 and have never used it, or needed it. In the setup on the tail section it will act like its in rate mode. After each input the tail will go back to center. As long as the servo at 90° (or as close to as possible) and the crank at the tail in 90° you will be fine.
        Raptor E700
        Raptor E700 Stretched
        Raptor G4
        Youtube Channel
        Conor
          On main screen 5.3 pro go to tail rotor
          click pro as two photos
          Santander Factory Team
          Proud wearer of 5 x EGS
            As Gixerman shows, it does have a rate mode option. You can switch between rate and HH from the Tx by using Bank switching.
              Thanks guys for all the info. I am grateful to you all. Just getting back in the hobby after long period with ill health so the 450
              will come in handy for a crasher lol. Thanks again.
