vertical tail fin stabiliser
  • #46
    Thanks for that Tom,
    im reading through that manual you linked.. i dont see how i would change to soft start.. or have i got the wring end of the stick again ?
    Trex 450 FBL
    Mcpx V2
    Foam plane sports Cub S
    Spektrum DX6I
    Phoenix sim
    Tarot 250 Quadcopter
    • #47
      t says 4, include soft start and governor mode . how do i switch it ?
      i mean how is it programmable ?
      Trex 450 FBL
      Mcpx V2
      Spektrum DX6I
      Phoenix sim
      • #48
        You don't have to. The manual shows that the ESC has three modes (1) airplane (2) heli+soft start (3) heli+soft start+governor.
        Both heli modes (you will be in one of them) has soft-start.
        • #49
          ok, il leave it just now, il look at it when im less tired.. i dont really understand TBH..
          thanks tho...
          Trex 450 FBL
          Mcpx V2
          Spektrum DX6I
          Phoenix sim
          • #50
            now it has a slow tail wobble ?
            i dont like that way i have to put the throttle stick WAY up before it takes off..it feels very unnatural .. any thoughts ?
            Trex 450 FBL
            Mcpx V2
            Spektrum DX6I
            Phoenix sim
            • #51
              just for heli with soft start, align governor is rubbish.
              Santander Factory Team
              Proud wearer of 5 x EGS
              • #52
                Im using that mini K-bar mate..
                im thinking il go back to my original settings.. but not if its the wrong thing to do..
                Trex 450 FBL
                Mcpx V2
                Spektrum DX6I
                Phoenix sim
                • #53
                  sorry i thought we was talking esc, if its a slow tail turn tail gain up a little,if fast lower slightly, if its a nod turn head speed up a little on curve
                  • #54
                    yes ESCs were mentioned.. sorry for the confusion.. i gotta admit , im kida lost now..
                    let me ask a fresh question...
                    could the fact that on my maiden, my vertical fin got a gouge or 2 in it due to it sticking in the grass and being hit by the tail rotors ( no visible damage to them ) could that be causing my wobble ?
                    just a thought..
                    Trex 450 FBL
                    Mcpx V2
                    Spektrum DX6I
                    Phoenix sim
                    • #55
                      just a thought..
                      if you have a bent tail shaft or hub, yes, or if torque tube I'm assuming may have a chip gear front or back maybe
                      • #56
                        its a belt drive ..but yes. il look at the whole tail assembly ..cheers
                        Trex 450 FBL
                        Mcpx V2
                        Spektrum DX6I
                        Phoenix sim
                        • #57
                          The heli should take off with the stick at about 60-70% up. If you're having to move the stick almost at the top you have a problem.
                          But certainly, the heli should NOT being taking off before midstick.
                          PS. Can you get a video of the wobble?
                          • #58
                            Compare these two vids - is your wag fast like the first, or slow like the second?
                            1/. https://www.youtube.com/watch?v=49oCoqCu5fc
                            2/. https://www.youtube.com/watch?v=vkKKWJUoM1c
                            • #59
                              more like the 2nd tom, but not quite, il film it tomorrow and post it, oh and thanks for your efforts to help.. much appreciated
                              Trex 450 FBL
                              Mcpx V2
                              Spektrum DX6I
                              Phoenix sim
                              • #60
                                Given that you pranged the tail fin before, it's likely to be something mechanical. The throtle and pitch curve changes will not have introduced that kind of wag. A slow wag like that is either that the tail gain value is too low (you can check in your TX). Or that you've got some kind of binding on the tail, for example, take a look at the following vid at about 1:30 in. If you disconnect the tail rod from the tail pitch slider, you should have lovely smooth movement of the tail pitch slider like his.
                                https://www.youtube.com/watch?v=KFTlKGE4sHE
