Originally posted by rob12770
View Post
vertical tail fin stabiliser
Before connecting your battery always make sure you check all your switch settings, especially flight mode and TH. Then check them again before you spool up to take off. Never ever skip those checks or presume that the switches are where you left them, they easily get knocked in transit or when you pick up the Tx.SAB Goblin 380 KSE - latest love thang
Blade mCPX - sold
Spektrum DX8 - for everything
neXt sim - the sim I started out with
I always check TH switch but i never even knew having the flight mode switched would do that.. it gave me quite a fright i can tell youOriginally posted by Peteski View PostBefore connecting your battery always make sure you check all your switch settings, especially flight mode and TH. Then check them again before you spool up to take off. Never ever skip those checks or presume that the switches are where you left them, they easily get knocked in transit or when you pick up the Tx.
but i was way back from it a good 20ft.
so this is normal ?? can i change it for safety reasons or should i just leave it as is ?
cheers RobTrex 450 FBL
Mcpx V2
Foam plane sports Cub S
Spektrum DX6I
Phoenix sim
Tarot 250 Quadcopter
It's normal. How else do you think RC helicopters fly inverted!? Once you get past the beginner stage - you should be flying in "idle up" so that the left stick controls ONLY the collective pitch. The throttle is pre-set and start-up is simply turning throttle hold off.Originally posted by rob12770 View PostI always check TH switch but i never even knew having the flight mode switched would do that.. it gave me quite a fright i can tell you
cheers Rob
That is one of the reasons why my suggested throttle curve gives a flat 70% once you get past the point where positive pitch will make the heli fly ... you want a constant head speed!Tom
Yes Tom, i get it now..Originally posted by tomatwalden View PostIt's normal. How else do you think RC helicopters fly inverted!? Once you get past the beginner stage - you should be flying in "idle up" so that the left stick controls ONLY the collective pitch. The throttle is pre-set and start-up is simply turning throttle hold off.
that makes perfect sense to me..
thanks again for your help, it is much appreciated
Mcpx V2
Spektrum DX6I
Phoenix sim
Honestly, just buy that e-book I linked to and read it through. It explains everything you need to know in layman's terms. There's a fair bit to digest, but better to do that first before you get into trouble! It explains throttle curves, pitch curves, flight modes, etc, etc, etc.Originally posted by rob12770 View PostWhy is it like this anyway ? for stunt or inverted or something i assume.. sorry for the noob questions but i am ..
Blade mCPX - sold
NP. Let us know how you get on. Honestly, you should find the heli much easier to control with those settings ...Originally posted by rob12770 View PostYes Tom, i get it now..
cheers RobTom
Tom, one last question if you don't mind, regarding idle up mode, i assume you would spool up normally then flick into idle up mode ? the reason i assume that is it seemed a bit violent when i did it by accident
cheers robTrex 450 FBL
Mcpx V2
Spektrum DX6I
Phoenix sim
Most speed controllers should have a "soft start" option that will give you a smoother spool up.
Personally I switch to idle up then flick throttle hold off to spool up.
I don't ever fly in "normal" mode, you will realise why when you accidentally go inverted in normal and you crash because your motor
Spooled down.
Best to learn to use throttle hold and idle up from the beginning.
Practice using throttle hold in the simsigpic
^^^ This. Most heli ESCs have soft-start such that any requested throttle value, when coming from 0% results in a steady ramp-up to avoid gears being stripped.Originally posted by Holst View PostMost speed controllers should have a "soft start" option that will give you a smoother spool up.
Certainly all beginners should be using throttle hold, but I disagree with the statement about using idle-up from the beginning. The reason being that many (most?) beginners start with 4-channel fixed-pitch helis. There is a tendency therefore to "drop the throttle" (ie. the collective stick) in a panic. When you're a beginner, panics happen often, and dropping the throttle happens often. With a beginners' normal pitch and throttle curve - this normally just results in a slightly heavy landing.....
Learn from the beginning with idle-up will result in a badly damaged heli very quickly in my view. Best to get a level of confidence first, then transition to idle-up when the TH reaction is instinctive in a problem.Tom
I agree.. I would not feel confident at this stage to go idle up, im pretty sure id wreck my heli pretty bad..Originally posted by tomatwalden View Post
Although i have seen others advising to start learning in idle up mode too.. i think maybe its a step too far for most beginners,,but i can only speak for myself..Trex 450 FBL
Mcpx V2
Spektrum DX6I
Phoenix sim
so getting back to my question.. i have a standard align ESC.. how would i enable a soft startup ? not that i will be trying idle up at the moment you understand, im just trying to get a handle on things..Trex 450 FBL
Mcpx V2
Spektrum DX6I
Phoenix sim
Which exact ESC or heli? Pretty sure it'll have soft-start enabled anyway - but more details required.Originally posted by rob12770 View Postso getting back to my question.. i have a standard align ESC.. how would i enable a soft startup ? not that i will be trying idle up at the moment you understand, im just trying to get a handle on things..Tom
It is a Blue one ...Originally posted by rob12770 View Postso getting back to my question.. i have a standard align ESC.. how would i enable a soft startup ? not that i will be trying idle up at the moment you understand, im just trying to get a handle on things..
lol.. its zip tied in so i can tell which model, but has a blue heat sink.. its standard align gear with the 450 Plus i believe..
It didnt seem like a very "soft" start when i accidentally started in idle up mode is all i can say..in fact i thought maybe id damaged my heli in some way..hence asking about that wobble..Trex 450 FBL
Mcpx V2
Spektrum DX6I
Phoenix sim
It's the RCE-BL35P. The manual can be found in the link below. Basically it DOES have soft-start for heli-mode, which means yours does have soft-start enabled. An abrupt (non soft-start) will only ever do one thing ... strip teeth from gears (generally the main gear - but occasionally the tail torque tube gears). Missing teeth is normally audible as the heli will sound rough.
Trex 450 Manuals - Page 5 - HeliFreakTom
