Honey Bee King 2 Problems
  • Honey Bee King 2 Problems
    Hello,
    i have been flying my heli since christmas and after a bit of set up alterations has been fine and have been flying until i had a wobbly landing and the blades hit the deck and smashed one off. i have put new blades on balanced it and checked everything over, but now when i go to fly the heli takes off and spins violently.
    i have tried altering the gyro and i have moved the servo on the boom further towards the main body but it still isn;t stopping it. is there anything else that can effect this?
    Any help would be greatly appreciated.
    Craig
    Have you checked to make sure all your servo's are working properly?
    It is easy to break them, or damage a linkage, make sure everything operates properly before you try to fly!
    regards
    Pip
      hello,
      yes i have checked all of the servo's and they are functioning correctly, is it just spending more time finding a balance between the gyro and the boom servo? i.e does 1mm make a big difference?
        If the heli is pirouetting, then the gyro or tail servo or linkage is not operating correctly.
        Have you adjust gyro gain at all, if so reset to 50% and try it again. Its hard to diagnose without seeing it!
        Another thought, just make sure tail servo operates the right way and gyro sense is correct too!
        regards
        Pip
          ok thankyou,
          yes it is spinning from tail in a clockwise direction but it is flying just spinning around constantly.
          will set back to 50 and start again, thanks
