Originally posted by Bluenose75
View Post
Blade mcpx settings for a pleb!
Set the TH pitch curve to 0,25,50,75,100. ... Move the collective stick to the exact middle (you can check on the monitor screen), then fold blades back against each other. If you've got zero pitch, they'll near as damn it, line up. If they form a significant V shape, you don't have zero pitch.Tom
They need to be parallel to the boom as well.Originally posted by tomatwalden View Postthen fold blades back against each other. If you've got zero pitch, they'll near as damn it, line up. If they form a significant V shape, you don't have zero pitch.
If they are lined up, but not parallelel to the boom, all this shows is that the positive on one blade equals the negative pitch of the other....
HTH
TTrev
Surely he needs to set it to 50,50,50,50,50? I don't use his TX, but it needs to be a flat curve for pitch, with no variation at all.Originally posted by tomatwalden View PostSet the TH pitch curve to 0,25,50,75,100. ... Move the collective stick to the exact middle (you can check on the monitor screen), then fold blades back against each other. If you've got zero pitch, they'll near as damn it, line up. If they form a significant V shape, you don't have zero pitch.
The idea is to force the blades to zero pitch no matter what you do with the stick :-)Helis: Oxy 2 FE / Oxy 2 Sport / Protos 380 / Oxy 4 Max / Gaui X3 380mm
Electronics: Spartan VX1e / Spartan VX1n / Spartan VX1p / MSH Brain2 mini / Jeti DS-14
Sims: Realflight / AccuRC / Phoenix RC (Wireless) | AccuRC (Wireless) | Realflight (Wireless)
Not sure how you figure that! Assuming no cyclic input, the collective pitch will be the same regardless of the orientation of the blades with the boom. Zero pitch should be zero pitch all around the disc!Originally posted by dillwhacker View PostThey need to be parallel to the boom as well.
HTH
T
That'll work too! I'm just used to using the linear curve because you need it when setting up a FBL unit.Originally posted by myxiplx View PostSurely he needs to set it to 50,50,50,50,50? I don't use his TX, but it needs to be a flat curve for pitch, with no variation at all.
The idea is to force the blades to zero pitch no matter what you do with the stick :-)Tom
I don't really get that either. Are you talking about the swash not being level?Originally posted by dillwhacker View PostThey need to be parallel to the boom as well.
HTH
TSAB Goblin 380 KSE - latest love thang
Blade mCPX - sold
Spektrum DX8 - for everything
neXt sim - the sim I started out with
That's correct for his TX, presuming 50% does actually equal zero pitch in reality. That's what he needs to check to make sure his swash is not too high or too low. If there is positive pitch on the blades at 50% then the swash needs lowering and vice-versa. For checking pitch range on a micro I temporarily set my TH pitch curve to 0/50/50/50/100 so I can check that centre stick gives zero pitch and that full negative and positive pitch are roughly equal. I just eyeball it on a micro, but you could measure the gap between the blades. Don't forget to reset your TH pitch curve to 50/50/50/50/50 afterward though!Originally posted by myxiplx View PostSurely he needs to set it to 50,50,50,50,50? I don't use his TX, but it needs to be a flat curve for pitch, with no variation at all.
Bluenose - this is the best £10 you could invest right now to cut through all the confusion on setup, even has a specific guide on setting up micros and it's a great reference guide for all cp helis:-
RC Helicopter Tips & Setup eBookSAB Goblin 380 KSE - latest love thang
Blade mCPX - sold
It's the same as setting pitch in any of your other flight modes, don't forget that the pitch curve is specific to the flight mode. Your TX should indicate which flight mode it is in when setting pitch curves, for example my DX8 indicates N/1/2/H flight modes on the pitch curve display. Zero pitch should be 50% on your pitch curve, so as described above, you need a flat pitch curve of 50/50/50/50/50 on your 'H' flight mode. But you must check that 50% does actually give you zero pitch on your heli, otherwise the swash needs resetting.Originally posted by Bluenose75 View PostHow do you set your pitch to 0 on throttle hold?SAB Goblin 380 KSE - latest love thang
Blade mCPX - sold
This thread has been a god send, thanks to Bluenose for starting it. I've just programmed my 130x with the Normal Mode Settings that Tom and Pete are advocating and at long last I feel I'm almost keeping up with it. The 130 is my least favourite heli of my four but that might soon change thanks to this thread. More importantly I'm now understanding what I'm doing and why. Thank you to all contributors, those answering the questions and those asking them.
Originally posted by Peteski View PostThat's correct for his TX, presuming 50% does actually equal zero pitch in reality. That's what he needs to check to make sure his swash is not too high or too low. If there is positive pitch on the blades at 50% then the swash needs lowering and vice-versa. For checking pitch range on a micro I temporarily set my TH pitch curve to 0/50/50/50/100 so I can check that centre stick gives zero pitch and that full negative and positive pitch are roughly equal. I just eyeball it on a micro, but you could measure the gap between the blades. Don't forget to reset your TH pitch curve to 50/50/50/50/50 afterward though!
If if its just a £10 then I think I will go for it, thanks for the link!Spektrum Dx6i
Blade Mcpx BL
Blade 200 SRX
Blane Nano QX
Yeah it's well worth the money, it's a well respected and easy to follow guide. The section on specific setup for cp micros is extremely useful when starting out and will save you a lot of hassle.SAB Goblin 380 KSE - latest love thang
Blade mCPX - sold
All I mean is, if you fold the blades back over the tail, and they line up, that only means zero pitch if they are parallel to the boom (viewed from the side).Originally posted by tomatwalden View PostNot sure how you figure that! Assuming no cyclic input, the collective pitch will be the same regardless of the orientation of the blades with the boom. Zero pitch should be zero pitch all around the disc!
If the tips line up but both blades are dangling down toward the boom, that isn't zero pitch.Trev
They can only both dangle together towards the boom if there is cyclic applied (the swash leaning backwards). Any positive or negative collective pitch will result in a V shape as the blades diverge away from each other.Originally posted by dillwhacker View PostAll I mean is, if you fold the blades back over the tail, and they line up, that only means zero pitch if they are parallel to the boom (viewed from the side).
If the tips line up but both blades are dangling down toward the boom, that isn't zero pitch.Tom
Or if the links are bent / badly adjusted etc. That was my point, it's not a definitive check for zero pitch.Originally posted by tomatwalden View PostThey can only both dangle together towards the boom if there is cyclic appliedLast edited by dillwhacker; 03-06-2015, 09:56 PM.Trev
Ok so managed to run 2 cells today outside using normal mode and survived! Just hovering, it did run away a couple of times but I got it back, had to drop it a couple of times into the grass but no damage as I used TH each time, it was windy so look forward to a clear day! Thanks all for the advice, it's quicker than the 200srx!Spektrum Dx6i
Blade Mcpx BL
Blade 200 SRX
Blane Nano QX
Oh yeah, it's quick :-D
First time I flipped a BL inverted I got a bit low and panicked, and went full negative. By the time I realised what I'd done the damn thing was upside down about 10 feet above the top of my house. Took some concentration getting it back down from there I can tell you!!Helis: Oxy 2 FE / Oxy 2 Sport / Protos 380 / Oxy 4 Max / Gaui X3 380mm
