Beginner Transmitter setting For Esky/Eflite 400-450
  • Beginner Transmitter setting For Esky/Eflite 400-450
    Hello peeps
    Is their a basic transmitter setting in general, for most transmitters? I have a new flysky i6 with the same settings as a dx6i. Ive put settings, but the heli is really twitch lol.
    I just want a basic setting for hovering
    If its the same as a DX6i this may help
    http://www.rcheliaddict.co.uk/e-flit...ade-400-a.html
      I ment the same as the imputs ect lol.
        FlySky i6 AFHDS2A 2.4ghz Radio Control System
        This is the transmitter ive just got. I just want my king for not to be so twitchy.
          Not sure if the dx6i is the same, but i think the values are. I keep looking for something, or someone who has put together a list of esky king 4 with a flysky fs i6. But nothing
            I tried the settings, but the head speed is too fast on normal mode. Its really still twitchy, any more settings i could try?
              This is whats on my transmitter.
              Please feel free to change and update my inputs, as im finding it hard to hover
              (Reverse)
              Ch1-normal
              Ch2-normal
              Ch3-normal
              Ch4-normal
              Ch5-normal
              Ch6-reverse
              (End points)
              Ch1-100%-100%
              Ch2-100%-100%
              Ch3-100%-100%
              Ch4-100%-100%
              Ch5-100%-100%
              Ch6-100%-100%
              (Aux channels)
              Ch5-source used
              Ch6-source used
              (subtrim)
              Ch1-center
              Ch2-center
              Ch3-center
              Ch4-center
              Ch5-center
              Ch6-center
              (Dual Rate/Expo)
              Normal
              Ch1-rate-60-expo-80
              Ch2-rate-60-expo-80
              Ch4-rate-40-expo-80
              Sport
              Ch1-rate-100-expo-0
              Ch2-rate-100-expo-0
              Ch4-rate-100-expo-0
              (Throttle curve)
              Normal
              L-0%
              1-25%
              2-50%
              3-75%
              H-100%
              Idle up
              L-0%
              1-25%
              2-50%
              3-75%
              H-100%
              (Pitch curve)
              Normal
              L-0%
              1-25%
              2-50%
              3-75%
              H-100%
              Idle up
              L-0%
              1-25%
              2-50%
              3-75%
              H-100%
              (Swash AFR)
              Swash type 120
              Aileron-35
              Eilervator-35
              Pitch+30
              (Mix)
              Mix #1
              Mix is off
              Master ch1
              Slave ch2
              Pos. Mix 50%
              Neg. Mix 50%
              Offset 0%
              (Gyroscope)
              Gyro on
              Mode normal
              Value 51%
                Good God.....lol
                  Originally posted by 1chris View Post
                  Good God.....lol
                  Good god!, as in omg!! Your going to crash? Lol Or good god the settings are back to front? Lol
                    Some of those settings look "wrong" to me.
                    Have you set the heli up properly or just copied settings?
                    With a flybar heli you need to do it properly.
                    It's not difficult but it's way to much to type on a phone.
                    Have a read of this
                    Finless videos - RC Helicopter Wiki
                    And ask any questions you have.
                      To be honest, most of the settings look OK to me, with a few minor things. First things first - are you flying in "normal" mode or "idle up". You should be flying in normal mode for two reasons
                      1/. The DR/Expo settings are more suitable for a beginner
                      2/. The idle up throttle curve is wrong.
                      The next thing I would suggest is to change your throttle and pitch curves for normal mode, to these :
                      TC : 0,35,70,70,70
                      PC : 30,40,50,75,100
                      As it is, your linear throttle curve will mean that your collective stick will be changing the motor speed AND blade pitch all the time. That in itself would make the heli a nightmare...
                      But besides the above "oddness", there's nothing fundamentally wrong with the settings - nothing that will make the heli react wrong.
                      Your expectations of flying a collective pitch helicopter may be unrealistic though - they're not easy!
                      Take a read of this : Are RC Helicopters Hard To Fly?
                      And perhaps consider getting a fixed-pitch (4 channel) heli to begin with ... Something like the Blade mSR / Blade 120SR or Blade 200SRX.
                        TC : 0,35,70,70,70
                        Thank you for helping
                        I've flown a Eflite 400, and mastard circuits with that heli. But ive not flown in a long time and never flown a esky king before. The swash moves up and down ok, the only thing that make my head hurt is understanding the gyro.
                          In which case, this may be simply that the E_sky is not a very good heli The Blade 400 may have simply flown better!?! But like I say, having the collective constantly vary motor power and pitch isn't going to help your cause!
                            I see, i did it on a budget lol. Ill try and see about them settings and see where i go from their. Wish i had someone near me to have a look.
                              You should be able to find a club fairly near you! Check out the BMFA club finder!
                              BMFA Club Map
