blade 200
  • blade 200
    Hello guys
    It must be problem blade 200 week.
    I have a problem with mail tail I think.
    After a crash I changed the tail blade, servo and up graded the tail, main blade grips but all it wants to do is spin round all the time.
    Thanks in advance.
    Dean
    Blade 200SRX
    Blade 230 S
    Trex 450l dominator
    Trex 500 Pro
    450 Forza
    RJX Extreme 50N
    1500 Varioo scale Jet ranger (scorpion motor)
    PL6 with coolice PSU
    neXt sim
    DX9
    If you had a crash, you can't really blame the heli for being weak! If the heli is spinning around, it is because the tail is not counteracting the torque of the main rotors. Does the tail rotor spin at all?
      Thanks.
      It spins intermittently.
      I tried swoping the contections round on the plugs then smoke starting coming out of the motor so it cant be going round the wrong way.
      After that the moter still spins the same.
      Dean
      Blade 200SRX
      Blade 230 S
      Trex 450l dominator
      Trex 500 Pro
      450 Forza
      RJX Extreme 50N
      neXt sim
      DX9
        Your best option will be to send the whole heli to Horizon's service department in Essex. They'll just fix it for you. They may charge for the replacement parts, but 9 times out of 10, they'll repair for free.
        About Us
          I will put it back to standard before doh.
          Thats right.
          Dean
          Blade 200SRX
          Blade 230 S
          Trex 450l dominator
          Trex 500 Pro
          450 Forza
          RJX Extreme 50N
          neXt sim
          DX9
            I think he meant "week" Tom, not "weak" :-D
            To the OP, if it was spinning around there are a few things it could be, but if you had smoke coming out of the motor then that's basically toast. Better to replace that motor than try to fly it with a problem and end up breaking more stuff in a crash.
            It may well be the tail motor was bad anyway, I believe it's the typical brushless motor with three wires, so if you do get the wires the wrong way round all that happens is it spins the wrong way. Smoke coming from the motor probably means you had a wire shorting in the motor and in that case even if it was spinning the right way it may not have had enough power to stop the heli spinning.
            If you're confident with your repairs, pick up a new tail motor and try again. Learning to repair heli's is as much a part of this hobby as flying them :-)
            Electronics:
            Sims: Realflight / AccuRC
