I only have a cheap set up and since flying the Trex it's been as good as gold.
I use the "Prolux 1-3 Cell Li-Po Charger DC 12v" & "Prolux 2-4 Cell Lithium Balancer"
My 12V Battery power source is fine, the last charge that was normal at 1.5 amps was with one of my Maxpoly batts where cell one had 4.26, cell two had 4.20, cell three had 4.22. this has been the normal charge rates since I've been flying and it has given me excellent flight times.
After my align batt cooled down I put it to charge at the 2amp charge setting (for the first time) as I wanted it to be charged quick, I've never done this rate before, as the highest I'd ever charged any batt was 1.5 amp.
And when charging at 1.5 or 1amp the charge unit usually got quite warm, I though it was strange when I felt the charger while charging at 2amps and it wasn't warm at all, then all the lights flashed saying the charging has been completed.
When I checked the voltage in the lo po after a 2amp charge, cell one 3.75, cell two 3.80 cell three 3.75.
It was the same when I tried to charge another Maxpoly after a flight, and this was charged after the Align battery, at 1.5amps, (thinking it 2amp setting doesn't work) and the charge per cell at this rate was a crappy cell one 3.75, cell two 3.80, cell three 3.75
I've got the 12V source batt on charge just to be sure, however the source batt has had more charges taken out of it before being put on charge again, plus each evening it's put on permanent float so its constantly trickle charged throughout the night, or on days it's not used, so I know my 12V source batt is in tip top condition, plus its only a few months old.
Any ideas, or suggestions guys,
