Puzzled
  • Puzzled
    After what I feel was good progress Friday with blade200 ie: take off fly forward and land four times,
    this morning I seemed to have taken a step backward,
    all that seemed to happen was when blade went light it flew backwards then when tried to correct with stick forward no response, then after that as I increased throttle blade kept tipping forward with no right hand stick,
    any ideas is it me or machine set up.
    https://www.flickr.com/photos/wallyboy/
    Blade200srx,
    Blade450x,
    Did you catch the safety switch? Took mine out today for the first time, wow I had a shock, it was a bit windy I was ok hovering but when I went a bit higher it started disappearing so I dropped the throttlle and brought it down, no damage just nerves shot! Had a few more lifts, in the end I came down in longish grass and the tail rotor disintegrated! Did notice a couple of times when spinning the main rotor up for a take of and the rear blade has not started spinning is that normal?
    Spektrum Dx6i
    Blade Mcpx BL
    Blade 200 SRX
    Blane Nano QX
      I didn't catch safety switch, it seemed to have a mind of its own...LOL
      as for rear rotor spinning mine does that as well, seems it kicks in after main rotor is quite high revs.
      I think if the heli's were more robust they would be easier to get used to, I keep worrying about crashing.
      My next plan of attack is go along to local indoor club, be cheaper in the long run me..thinks
      Blade200srx,
      Blade450x,
        The problem with making 'more robust' is that would mean more weight. To make them crash proof would mean they were so heavy that they wouldn't fly, or at least wouldnt fly worth a damn.
        It's hard to say what the problem with the back and forward drifting/tipping.. most likely it's just more practice you need but hard to say without being there. Often all that's needed is a bit more commitment to get it in the air, the FBL controller cant really work properly until the heli is clear of the ground.
          hope to get a bit of advice when I go to indoor heli club.
          Blade200srx,
          Blade450x,
            I would suggest getting a micro to practice on indoors. Something like an mSRX or a micro quad like the nano QX. Since Christmas I've logged countless flights on my nQX with no damage at all. It's really building my confidence.
            I presume you are using a sim too? Again big confidence builder.
            When I look back over the last month, I realise I'm now in a much better position to begin flying a 200 SRX or even a larger CP heli for that matter. Proof will be in the pudding obviously, but my confidence has gone from zero to quietly confident I could handle one in basic flight.
            Blade mCPX - sold
            Spektrum DX8 - for everything
            ne
              I don;t think that's true at all. It's a matter of design and application. I see no eason why a heli can;t b designed with shear pins to protect gears and break points to protect fuselage etc. the issue with doig that is the R&D to allow a wide flight envelope and the lack of spares sales.
              PGK
                Just an idea, but check for trim on your tranny? Had one of my helis wanting to tip over, and somehow had got a bit of trim added.
                TDR (awesome machine) and TDF (almost built)
                Strike7
                SAB Kraken 700 & 580, G570KSE, G420, Buddy 380
                XK-K110 x4
                Futaba 18SZ
                Member of the MKHELI Club
                  Well the plastic gears cost next to nothing to replace and protect other more expensive parts by conveniently stripping teeth if overloaded in a crash. So not much point in shear pins on a heli like this? Would be a different story with all metal gearing though. It seems like a reasonable design compromise to me, but I haven't seen one close up yet. I spoke to the shop guy about their reliability (after reading a few internet tales of their fragility) and he reckoned they were generally okay if not pushed too hard with advanced flying. It's supposed to be a trainer for beginner/intermediate rc pilots really, not something to push the limits with. All assuming you don't get one with a duff tail motor etc. which is more a QC issue.
                  Blade mCPX - sold
                  ne
                    I was actually thinking about heis generally rather then necessarily beginner ones. And whilst your gears might be cheap they get more expensive - and sometimes more nuisance to change on the bgger models. Accessing from the side to drift out one pin and refit... then ther's undercarts...gorilla skids on 450/500 are virually indestructible.. so not supplied with the kit. The gobblers have break free tails.. but not other models. Blades are one of the biggest expenses. The scott grey 710's on my gasser must be pshing £150 now...althugh ;m not sure how you could make those safely break free and not fly through a headless crowd.
                    PGK
                      Yes I am looking for indoor micro, the thing I have found with blade is I can't seem to get it to hover like you see in many YT vids,
                      Thanks mike I have all the trims on centre, which was advised,
                      Blade200srx,
                      Blade450x,
                        I'm not sure how you could make those safely break free and not fly through a headless crowd.
                        Wouldn't matter if they are already 'headless'
