Hi Guys Still Trying To Set Up Lama V4, Can Anyone . Bogey. Mazefaze, Or Anyone Else Elaborate On Gain , I Tried Altering Mine Witch Did Help Some But It Made Heli Go Fast Reverse As Well. Thanks For Help Guys........................ron.
Gaining Experience
The LamaV4 gyro is a yaw rate gyro.Originally posted by NEWBIERON View Post[...]Can Anyone [...] Elaborate On Gain [...].
It measures how fast the heli is yawing (rotating in the axis of the mainshaft), and mixes an input to the yaw input from your l/h stick to reduce the yaw rate.
The greater the gain, the bigger the effect.
It's a bit like the velocity damper on a door closer, or a vehicle shock absorber. The damper acts to slow the movement. The faster the movement, the more it resists.
If the gain is too much, you can get oscillatory effects - eg the tail 'wags'. Here, the input is so great, it accelerates the tail in the opposite direction.
Ideally, the 'proportion' should be set so that the heli doesn't significantly yaw left or right with no stick input or trim.
To a degree, the gain can mask this effect, by slowing the yaw, even though the heli is out of trim.
Here's a helpful piece: http://www.rcheliaddict.co.uk/showthread.php?t=7952Yes, it's th@ tw@ Scallyb@...
ron
this is an esky lama v4?? if so.. center the trims and hover
turn up the gain slowly abit at a time till the tail wags. then back it off till it holds steady, if the heli now turns slowly adjust the proportional.if the heli turns clockwise= adjust anticlockwise. and vice versa, disconect after each adjustment.
once thats steady if the heli drifts forward. shorten the left hand servo arm. if it drifts back lenthen it.
if the heli drifts left shorten the right servo arm, if right lenthen it.
(check first which servo does which action as i may have left and right mixed ..hey its 12.45 saturday
do all this on a fully charged battery that has had about 30 sec's run out of it. be patient every thing you adjust will affect something else so you may feel your going around in circles (forgive the pun)
cheers boggy, ihave done as you all say centred trim turned prop little by little ,dissconect and reconnect after each time . i have gone fully anti clock now ,and even with fuul right rudder it still turns left , tail right. try to control with right rudder but she drops very quickly. iknow i have to give more throttle , it would be ok if ihad somr trim to compensate .thanks for your help. iam going round in circles here
Are you turning the right pot? If i remember correctly i had 2 pots on the Esky Lama i had. One is the mixer prop and 1 is the gyro gain.
Lee
hi lee. yes mate turning prop pot not gain pot. thanks for videos mate , have gone all the way anti clock ,still have full right trim with lots of right rudder , still falls rapidly, any advice welcome mate ,regards to you ,girlfriend and littleuns. , rom
hmmm... is there any chance you can do us a video so we can see what you mean by falling rapidly? So what has changed when you did turn the pot all the way anti-clock wise?
Lee
ron if the heli is turning left you should be turning the prop pot clockwise!!
always view the heli from behind and above. and watch the nose
so heli turns left = anticlockwise therefore turn the pot clockwise
heli turns right=clockwise therefore turn the pot anticlockwise
yes mate spot onOriginally posted by NEWBIERON View Posthi ron ,just to clarify, the nose goes left tail right, turn pot clockwise??. thanks ron.
