flying help see last post
  • flying help see last post
    hi there guys managed to break the end of the main blades off powering down and heli fell over over oops, ok now my local hobby shop have blades i know they have ones for a trex 450 now are these compatable ? orginal ones are 280 long , Ron if your there any idea on what they sell up hobby hanger ?
    thanks guys
    Rocky
    they sell trex blades which should fit. i think the cheapest are about £ 9.99. or ask aide if blade 400 woodies will fit (they should be close) at £7.99
      oh well thats cheap was looking on there website and there were blade like 30-40 quid bitu longer tho, ah thats not bad. do i need to have blades the same length as orgianl ones ? or wont it make alot of difference?
      Rocky
        i think the 400 has a short tail boom so be carefull best to take it with you and talk to aide or rich they will sort you!
          ok, thanks for the help.
          rocky
            The x400 std blade grips need some 1mm thick washers 2 per side to fit the std trex main blades.
            The std x400 will take the trex 305 woods with these spacers, but 325 blades you need the longer tail boom, longer tail pushrod and longer belt to make it the same size as trex450 or mini titan.
              ok well got some blades 9 quid cheap as chips. put the black grips on the blades and fitted nicely.
              ok problem i have now is when i get it off the floor and try to hover or move about slightly the tail moves from side to side making it very hard to fly it doesnt move violently just mover like 12 inches ither way any ideas ?
              also does aline esc come with a built in bec as this may be a problem ?
