Dx6i to dx8 buddy
  • Dx6i to dx8 buddy
    Im just wanting to gather a better understanding of this, i have already looked at some youtube vids and read some posts, but im just looking to clarify what i think.
    Basically a friend has an old trex 600 which he is a little nervous to fly. He uses a dx6i and i use a dx8. In order for me to buddy him on his heli would i have to:
    *bind his heli to my dx8 and set up.
    *use the dx6i as a slave
    *set all settings on the dx6i the same as my dx8
    Then its just a case of me holding the switch while he practices the hover and letting go of the switch if he gets into trouble (obviously taking control)
    He can already hover as he has sim practice and also a smaller cp heli under his belt.
    This will also be done with training gear on.
    Thanks in advance
    Thanks in advance
    Using the same system with the DX6 as the slave, have to watch the CCPM as setting both the same seemed to confuse the heli and only had minimal movement on the swash.
    Thankfully one of the guys figure it out and ok now - although not certain everything is set the same.
    Once set just hold the button down and fly
    Trex 500 Flybarless - Kbar
    Agile 5.5 - MSH Brain
    Goblin 630 - Vbar
    Hirobo Lama SA315B
    New DX6
    JR XG8
      Does the slave use 1 servo 90 degree like the sim?
          I used a similar setup a couple of years ago. Master was dx8 and slave was dx6. Set up a new model on the dx6, all default settings.
          Found this on YouTube. It may help.
          Test at it all out before you take off! Disconnect the motor if you need to.
          Spektrum DX8 and DX6i Buddy Box Setup "How-To" - YouTube
          SAB Goblin 700 Beastx
          Align T Rex 700e Beastx
          Mikado Logo 550sx Beastx
          Futaba 8fg.. oooohh
            Thanks a lot. Already watched that. Going to try it
              make sure you test all controls first. Some may need reversed.
              Futaba 8fg.. oooohh
                Yes will do. Will test everything before flying
                  Yes it does, dx8 is on 120 I think, if the slave is the same it seemed to confuse the heli - no movement in the swash
                  Goblin 630 - Vbar
                  Hirobo Lama SA315B
                  New DX6
                  JR XG8
