msrx or nano
  • msrx or nano
    hi guys, someone i just met has offered me either of these helis but i dont know which is easiest to fly.
    i had the nano before and i flew that a few times but it was still a handful but never tried the msrx and just wondered if any one could tell me which is the easiest to fly please?
    i am still new to helis
    many thanks
    Msrx would be easier as it's a fixed pitch helicopter, the Blade Nano is a collective pitch which is a little more difficult to fly
    Phil
    Align MR25 Racing Quad
      i thought the msrx is a collective pitch, cheers for the confirmation.
        Specs for the Blade msrx :-
        Approximate Flight Time: 5-6 minutes
        Battery: 150mAh 1-Cell 3.7V 25C
        Completion Level: Bind-N-Fly
        Experience Level: Intermediate
        Flying Weight: 1.09 oz (31 g)
        Height: 3.27 in (83mm)
        Is Assembly Required: No
        Length: 7.44 in (189mm)
        Main Blade Material: Plastic
        Main Rotor Diameter: 7.13 in (181mm)
        Number of Channels: 4
        Recommended Environment: Indoor/Outdoor
        Rotor Type: Fixed Pitch Single Rotor
        Size/Scale: Ultra Micro
        Tail Rotor Diameter: 1.46 in (37mm)
        Phil
          Specs for the Blade Nano:-
          Approximate Flight Time: 4-5 minutes
          Battery: 1S 3.7V 150mAh 25C LiPo (two included)
          Experience Level: Advanced
          Height: 3.11 in (79mm)
          Length: 7.75 in (197mm)
          Main Rotor Blade Length: 3.35 in (85mm)
          Main Rotor Diameter: 7.75 in (197mm)
          Number of Channels: 5 channels
          Rotor Type: Collective Pitch Single Rotor
          Swashplate Type: 140 CCPM
          Tail Drive: Direct Drive
          Tail Rotor Diameter: 1.57 in (40mm)
          Type: Electric Collective Pitch Flybarless Helicopter
          Weight: 1.05 oz (29 g)
          Phil
            Iv got a upgraded Nano for sale hear an i'm open to reasonable offers
            http://www.rcheliaddict.co.uk/sale/1...eli-swash.html
            the nano QX is also a very good learning tool if thats what your after as with the self levelling you can learn orientation without losing control.
            This hobby is so dam addictive
            Trex 600n PRO RJX head with BeastX
            Trex 450 PRO
            Blade nano CPX(upgraded)
            Nano QX quad(ACE)
            DX7
            Phoenix V4
              I would have thought both would be twitchy outside in anything other than a flat clam day making them tough learner models?
                the beauty is you dont need to fly outside. the quad takes more wind than the heli. I would not recommend a beginner to fly them in anythinh about 7-10mph wind
                Sent from my GT-I9300 using Tapatalk
                Trex 450 PRO
                Nano QX quad(ACE)
                DX7
                Phoenix V4
                  above
                  Trex 450 PRO
                  Nano QX quad(ACE)
                  DX7
                  Phoenix V4
                    I've got both, the msrx was my first heli followed by the nano. Outdoors only in still conditions (at first), indoors only when you've moved your wife's orchids to a safe place, usually where the cat is hiding. To get the best from the msrx you really need a programmable transmitter, the DX6i is ideal and is readily available second hand. You 'must' have a DX6i or equivalent for the nano. They both take the same battery and are pretty crash resistant but easy to repair when necessary. Be warned however, what seems like a free/cheap offer will soon get very expensive, whatever you choose today will soon get upgraded/up sized tomorrow.
                    And to answer the question you asked, the msrx is the easiest to fly.
                      IMO , with out a dout the msrx is the one you need , I started on a msrx then got a nano , even tamed down the nano is a wee wasp & I never liked it , a nano for learning could easily put you off for life , I think the advice Euclid has givin you above is spot on , regards kenny d
                      Goblin , 380 Carbon
                      Oxy 4 - 360
                      Oxy 4 - 325
                      Oxy 3 - 250 , 3s
                      Oxy 3 - 250 , 4s
                      Oxy 3 - 280 , 3s
                      Oxy 2 - 190
                      Oxy 2 - 210
                      Spektrum DX9
                      Revolectrix PL6 & PL8
